GT 50 dating
  • FT1-511 GT 50
  • FT1-511 GT 50's Avatar Topic Author
GT 50 dating was created by FT1-511 GT 50
Hi all ,
hope you can advise a new member ,
FT1-511 framed machine with low mudguards and silver/ blue tank decals.
This was a field bike without seat, lights and loom paperwork
Hoping to resurrect and possibly restore but struggling for year and correct parts.
Was this model sold in the UK?
I will post pics soon.
Any info would be a start
Dave
07 May 2020 15:00 #1
Replied by Gr8uncleal on topic GT 50 dating
Welcome! from near Salisbury, Dave!
Are you able to post photos? Also, there will be a model code stamped on the body of the carb somewhere. It will be faint and probably covered in crud, but it will be there!
Regards.
Alan
08 May 2020 00:58 #2
  • FT1-511 GT 50
Replied by FT1-511 GT 50 on topic GT 50 dating
Thank for the response Alan, I am near Silverstone.
Bike is partially stripped so no complete pics but some shots attached.
Engine and frame share same number
Carb has TK on but no numbers on body only 16 which is bore size I guess?
Tyres are 14” rear and 15” front
So far I have removed, front wheel,forks, oil tank, fuel tank and mudguards. Tank looks original paint and sticker. Rest has been done in a lovely silver hammerite it seems!
Last ran 10 years ago as a field bike so tank is rusty inside and no spark.
Mag is wired direct to coil and no looms or lights fitted.
Any recommendations for parts would be good.
Many thanks again
Dave
08 May 2020 06:15 #3
Dave
Look on a flat surface in an area on the carb facing the barrel. Copy of a RD200DX Teikei carb attached.
Alan
08 May 2020 06:38 #4
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=302978104379&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=301703008197&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by MarkT on topic GT 50 dating
Carb should have the model code stamped in it as Alan said....
Another common place... but less reliable than the carb... is look over the cylinder carefully. Often there is a model code cast into the cylinder someplace along the base or around the reed valve. My guess is it may be a 1977 with a 375 model code.
08 May 2020 07:10 #7
  • FT1-511 GT 50
Alan
Thanks for all that, I didn’t want to purchase manuals from Ebay without more info, I’ll try that.
I’ll have another look over the carb tomorrow but I’m sure there’s no other numbers.
I’ll keep you posted
08 May 2020 12:48 #8
  • FT1-511 GT 50
Hi Mark
Thanks for that I’ll have a look over the cylinder tomorrow and take some more pics of the carb.
This is all assuming its still as it left the factory....
frame and Engine carry identical numbers so I’m hoping it’s still fairly standard.
Regards
08 May 2020 12:53 #9
  • FT1-511 GT 50
Hi all
Unable to upload any more pics on site for some reason
Carb is stamped 37502 7E
Still chasing a 375 parts list
Thanks all
14 May 2020 06:42 #10
