71 yamaha dt1 mx 250 magneto replacement
  • DaNewbs
  • DaNewbs's Avatar Topic Author
my magneto coils are all messed up im trying to find out if i can buy a hole new magneto setup or a site to get a new source coil i dont have a battery or lights but have lighting and charging coils
14 Mar 2020 12:09 #1
Replied by RT325 on topic 71 yamaha dt1 mx 250 magneto replacement
Can do away with the lighting coils & just earth the source coil on its own for mx. If the source coil is in a bad way then 'oh well' still gonna need one sorry. Could fit a later model CDI mag complete off a DT400 near the end of the run or a DT250 as went CDI in "79 i think. For that matter a points mag of a DT250 of any year [love points mags].
14 Mar 2020 14:56 #2
  • DaNewbs
Replied by DaNewbs on topic 71 yamaha dt1 mx 250 magneto replacement
So are you saying i should switch to a cdi? If not would you have a website you would recommend to buy a new source coil?
20 Mar 2020 12:49 #3
Replied by jcarr on topic 71 yamaha dt1 mx 250 magneto replacement
Your mag just looks crusty.
Pull the points and condenser and check coil continuity.
Now’s a good time to get an ohm meter if you don’t have one.
Sand the rust off the coil faces. It won’t be pretty but might work.
The service manual has a pretty good diagnostic section on the ignition,
you can find it in the docs.
20 Mar 2020 14:42 #4
Replied by DEET on topic 71 yamaha dt1 mx 250 magneto replacement
I do restorations, if you don't find what you need....
The following user(s) Liked this Post: Snglsmkr, Super90
20 Mar 2020 15:26 #5
Replied by 2fishkev on topic 71 yamaha dt1 mx 250 magneto replacement
Money well spent. Comes with a heaping piece of mind.
21 Mar 2020 09:50 #6
  • DaNewbs
i would like to do that what that usually cost?
21 Mar 2020 12:32 #7
Replied by Bigdog302 on topic 71 yamaha dt1 mx 250 magneto replacement
To have it restored? I would send Deet a Private message and ask him. He does Quality work from what I have seen and it is hard to go wrong with him.
Dave
Jesus is Lord!
21 Mar 2020 12:44 #8
I fitted an RT2MX small rotor mag onto a rough old Kitted DT1 that was traded in at work & used it for a while between selling one bike & waiting for the new model to arrive. Man that bike was quick & the mag worked a treat plus saved weight. Any of those mags--DT2MX [small rotor points] RT2MX cdi small rotor or even MX250, MX250B YZ250C & more except the C & think later had a retard built in at high revs which sort of killed things unless the motor is designed for it. Anyway--where was i [lost lol].
21 Mar 2020 19:22 #9
Replied by 70s250 on topic 71 yamaha dt1 mx 250 magneto replacement
Hey there, I’ve got a 1970 dt1f 250. It’s got a pretty rusty magneto and won’t run. Is that something you can restore?
02 Apr 2020 16:28 #10
