Re: Oil pump removal
  • Dirt clods
  • Dirt clods's Avatar Topic Author
Re: Oil pump removal was created by Dirt clods
1975 Yamaha DT 125 Enduro
Theres only two screws the hold the pump in place after removing them just twist the pump will come right off. Keep your eye on a little washer you'll need that.
The oil line reservoir is easy to disconnect from the pump just one small ring wire clamp. Now the other one is a bit tricky I come to find out it has a metal barrel holding the line in place I tried to remove it but just ended up cutting the line instead.
And I actually bought some screwdriver Bit set that'll grip the Phillips heads "JIS" Bit set
Still awaiting new pump
23 Oct 2026 18:42 #1
  • john.lockwood5@bigpond.com
  • john.lockwood5@bigpond.com's Avatar
Replied by john.lockwood5@bigpond.com on topic Re: Oil pump removal
What is the relevence of the small washer? If the washer is missing, anyone know what the size is or where to get one.?
24 Oct 2026 18:11 #2
Replied by DEET on topic Re: Oil pump removal
I will be interested in seeing this "new pump".... I understand it is a Chinese replacement and not a new old stock pump from Yamaha.
I have never heard of anyone offering a replacement..
The following user(s) Liked this Post: MarkT, swm, DVM, Ht1kid
24 Oct 2026 19:09 #3
Replied by Rick C. on topic Re: Oil pump removal
yeah, if you have the original oil pump you should send it to DEET for reworking.
He is the best!
But as of this date..I do not know if he still services oil pumps. Hope he does because I need to contact him. I have 2 to go!
The following user(s) Liked this Post: MarkT, DVM, Ht1kid
25 Oct 2026 02:10 #4
  • Dirt clods
Replied by Dirt clods on topic Re: Oil pump removal
Yeah it's like rolling the dice on TEMU I'll keep you posted when it arrives?
25 Oct 2026 20:24 #5
  • Dirt clods
Well see if this pans out and Deet is still active!
25 Oct 2026 20:28 #6
CAN'T keep a good DEET down as I say.
Great friend and ol' time ridin buddy!
26 Oct 2026 02:52 #7
I am still restoring them.
By the way Rick.... I still use those T-shirts you sent. Reminds me of you and Moab every time I put it on!
The following user(s) Liked this Post: Rick C., MarkT
26 Oct 2026 11:31 #8
Replied by RT325 on topic Re: Oil pump removal
Too try and be fair to DEET but here's an oil pump for a PW50 & the V50 V80 V90 type scooters i grew up fixing scooters.
So i'm not showing a CT2 type but they're up there too.
Our dollars has no value in NZ, yet they offer free shipping on an $11.59 pump.
Price might change if i sign in.
Ok i did sign in then it jumps to $18.79, bit strange, but i often by [junk] off them & never had a problem--just saying.
The mind boggles as to how they make stuff so cheap.
www.aliexpress.com/item/1005010570812752...%7C_p_origin_prod%3A
Last edit: 26 Oct 2026 16:41 by RT325.
26 Oct 2026 16:35 #9
Why not post the link to the CT2 instead of an unrelated model?
I looked around and didn't see one.
HOWEVER... I did see one advertised that it is an exact replacement for any 100cc through 400cc Yamaha.
How can you adjust the output for that large of a range? How does its gearing mesh with multiple pitch-ratio worm gears that are found on all those bikes?
How do you connect the oil supply line when is on the rear of the pump and faces the case it is mounted on?
I guess all these roadblocks don't seem hard to work around when it only costs $18.
Can't wait to see how it all works out.
The following user(s) Liked this Post: Rick C., MarkT, Swoop56, Ht1kid
Last edit: 26 Oct 2026 19:15 by DEET.
26 Oct 2026 19:14 #10
