dt400 project
- wayno
dt400 project was created by wayno
hi all, just picked up a project bike for the winter months, dt400 1976 import from states which i have to register after a dating letter, put a battery on it and only getting a rear light working so may be wiring problems, looked at the web but cannot find a replacement aftermarket loom anywhere, are they available or do i have to repair/remake another? wanted to check the wiring before a strip down just to know where i stand.
cheers wayne
cheers wayne
- 750kr1
Replied by 750kr1 on topic dt400 project
Hi Wayne,
I did the same 18 months ago, I don't know about the loom on yours but there have been differences on mine to wiring info on the web, the only problem with mine has been the fitting of a different ignition system with the 12v upgrade and that was sorted yesterday on here by another member. I was thrown a little after rebuild when the headlight didn't work, then realised that it only gets its feed when engine is running.
best of luck Keith
best of luck Keith
The following user(s) Liked this Post: wayno
- wayno
Replied by wayno on topic dt400 project
Thanks Keith, apparently the guy to contact about a loom is feet, had nightmares with a loom on a z900 I built a few years ago, ended up with a new loom so price depending, first as last.
29 Aug 2019 02:32
Replied by Gr8uncleal on topic dt400 project
Or maybe even DEET!!
29 Aug 2019 03:45
- wayno
Oops I stand corrected..
29 Aug 2019 09:08
It's a shame that the DT360A and DT400B/C looms appear to be different, as I might have a spare 360 one soon.
29 Aug 2019 09:59
- wayno
shame, been in touch with DEET and he can sort one if needed.
29 Aug 2019 14:19
Replied by RT325 on topic dt400 project
As good as a new loom will be,--what is so bad with your existing loom that it needs changing.
29 Aug 2019 16:14
- wayno
Nothing that I know of at the moment, from past experience with old electrics one problem leads to others, was testing the water as to what's available should the need arise.
30 Aug 2019 03:36
I would imagine that the DT has got only about a third of the wiring that the Z has, so hopefully no insurmountable problems!
30 Aug 2019 04:49
