Dt125 ño lights
  • jtb605a
  • jtb605a's Avatar Topic Author
Dt125 ño lights was created by jtb605a
Hey everyone , I had to go with aftermarket headlight and 4emove factory plug. Black should be ground but can't find a black one that checks to ground in the bucket. Also can someone please tell me what the ohm reading for lighting çoil should be ? As always thanks for your help. 1980 dt125 usa model.  Problem solved , bad ground connections  thanks for the help.
Last edit: 03 Sep 2023 07:12 by jtb605a. Reason: Problem solved
31 Aug 2023 06:36 #1
Replied by Tinkicker on topic Dt125 ño lights
If we knew the year and market destination of your 125 we would be able to help you.
31 Aug 2023 07:20 #2
  • jtb605a
Replied by jtb605a on topic Dt125 ño lights
1980 dt125 usa
31 Aug 2023 10:32 #3
Lighting coil. 0.19 ohms at 20C on the yellow wire.
Run a black wire from a ground on the frame.
31 Aug 2023 10:47 #4
  • jtb605a
Do I mean yellow wire to red probe and black probe to ground and meter set to what ?
31 Aug 2023 11:22 #5
Replied by MarkT on topic Dt125 ño lights
Headlight runs on AC and engine must be running.
31 Aug 2023 15:37 #6
  • jtb605a
Yeh , it's not working  only light burning is little blue one in the tach.
31 Aug 2023 16:16 #7
Stock headlight had 3 wires, yellow, green, and black.  Black was ground.  If it's not anymore then maybe that was why original headlight didn't work?
Little blue light (high beam warning) needs a ground wire too and it connects in bucket.  If it works (only with engine running), stator must be putting out something and there must be a ground?
This model is a standard 5 3/4" headlight with many options for replacement without cutting up the wiring so hard to help much more as I don't know what you or someone else has done to the wiring and what you're trying to do now.
31 Aug 2023 16:32 #8
  • jtb605a
Black is ground on headlight. I ran a ground to the frame for it. When I get it started back up I'll figure it out. Other headlight wires are correct per wiring diagram. If I was certain of the coil resistance measurement it would help save time. Thanks
31 Aug 2023 18:14 #9
Factory Service Manual (and 1980 supplement) for that model is in the Tech Library.  Specs and test procedures are there.
01 Sep 2023 11:19 #10
