hardware for decompression lever
  • Huskyking
  • Huskyking's Avatar Topic Author
hardware for decompression lever was created by Huskyking
would anyone have info for hardware and collars used to attach decompression lever to the clutch perch. Im finding that this hardware is very difficult to find.
thx for any help or suggestions.
08 Sep 2026 10:42 #1
Replied by Gr8uncleal on topic hardware for decompression lever
Are you looking to fit it on top of the perch, or underneath (as on the RT3).
08 Sep 2026 12:55 #2
Replied by Schu on topic hardware for decompression lever
My RT3 has the lever on top.
imgur.com/a/9SVwQy1
08 Sep 2026 14:08 #3
  • Huskyking
Replied by Huskyking on topic hardware for decompression lever
Thanks for the replies, I was hoping to place on top, and yes I have an RT3 Im refurbishing.
08 Sep 2026 16:26 #4
So what items do you have and what items are you missing?
Do you have the lever and the base for the lever?
If so, then I believe all you need are some spacers and mounting screws.
Does the photo I linked help you in any way?
08 Sep 2026 16:37 #5
Looking at the photo in your post from back in June it appears you have almost everything needed except for one spacer and screw. So I’m not sure what you are looking for.
08 Sep 2026 16:44 #6
  • Huskyking
yes I have everything except the screws or bolts and collars and or spacers.
the old photos show I have one collar and screw,
the other side appears to take a smaller collar and shorter screw.
If someone had the hardware for both sides I would take it, that way I would likely have everything correct.
08 Sep 2026 18:24 #7
I understand now. Your goal is to find correct Yamaha parts to replace your missing spacer and screw.
Otherwise you could simply measure the gap and make your own spacer using whatever length screw is required.
Good luck with your search. I will let you know if I ever come across them. Did you ever reach out to DEET as suggested in one of your earlier posts?
09 Sep 2026 04:23 #8
  • Huskyking
exactly, yes may have to McGyver something up...thx for your help, oh yes contacted Deet, he did not have anything.......
09 Sep 2026 04:46 #9
The following user(s) Liked this Post: MarkT, pabdt, Schu
09 Sep 2026 08:13 #10
