Exhaust gasket
- Aubs
Exhaust gasket was created by Aubs
Hi , Ive just had delivery of exhaust gasket for my ex USA 1973 DT250 Part number 2481462310. I expected an " O " ring but it is a 12inch length of rubber about 2mm thick. It took a fortnight to get to Wales so I dont wish to cock it up when fitting.. Consequently Ime asking you out there to give me instructions on fitting. Just to clarify this gasket does not fit between exhaust and cylender head but between exhaust pipe and manifold..
Aubs from Wales.
Aubs from Wales.
13 Feb 2021 08:19
Replied by Gr8uncleal on topic Exhaust gasket
Some folks are happy to use a single 'layer', others two. Whichever you decide, wrap it around the exhaust to determine the length you need and cut there. You then just force it into the gap between the exhaust and the manifold.
Like quite a few Yamaha parts now, you buy a fixed length and cut to the size required.
The manifold is two piece and does tap apart (it is a press fit). You might want to consider splitting the manifold to give it a good clean before re-assembling and fitting the new gasket. Some here have reported that they couldn't get a good seal until this was done.
13 Feb 2021 09:52
- Mothersbaugh
Replied by Mothersbaugh on topic Exhaust gasket
Others here say that another good idea is to run a string of______(can't remember what it's called, but someone will remember and bail me out; high-temp silicone something or other?) out of its tube on a clean dry piece of metal or plastic (something it won't stick to), and then dry that til it's no longer tacky. Stays flexible and you can roll it up and use it to fill the gaps as well.
Help me out, some of you who use that other stuff...Please?
13 Feb 2021 14:16
- Midlife Motor
Replied by Midlife Motor on topic Exhaust gasket
Red RTV silicone gasket is it
13 Feb 2021 16:15
Replied by MarkT on topic Exhaust gasket
I think the person(s) that advocated the "homemade" strings suggested making them on wax paper?
13 Feb 2021 16:25
- Midlife Motor
Yes it was DEET and I have followed his recipe and had great results. It does take a bit of practice with applying the right thickness of goo to the wax paper. It's actually quite fun, like playing Play Doh with my grand daughter
13 Feb 2021 16:44
- Mothersbaugh
Thanks guys. I knew someone would remember better than I did what it was all about.
13 Feb 2021 17:12
When I said "exhaust", I really should have said the part of the manifold that you are going to insert the gasket into, just so that the length matches one or two times the circumference.
- Aubs
Replied by Aubs on topic Exhaust gasket
Great answer. Thanks a bunch. I alwaus look on this forum for advice.
14 Feb 2021 01:01
14 Feb 2021 03:06
