DT2 Clutch Actuator mod
  • Bartman512
  • Bartman512's Avatar Topic Author
DT2 Clutch Actuator mod was created by Bartman512
Ok Ive done several searches but cant actually find the actual mod or which one to order. Mine is broken and Im hoping there's a better part that will work for a 72 DT2.
03 Dec 2020 15:42 #1
Replied by Mothersbaugh on topic DT2 Clutch Actuator mod
I think I read that kdi is working on a reproduction clutch actuator for the DT's and RT's. And I right? RickC (Rick Corona) said that in a post maybe two weeks ago. Don't know what Dave's target date for release is, though.
03 Dec 2020 15:55 #2
Replied by Hammer on topic DT2 Clutch Actuator mod
Bartman512,
From an earlier post:
See one of the many "clutch actuator" threads on this site. These will explain both the problem, and permanent cures, if you want them gone forever. You CAN get repops of the whole actuator if you'd prefer, but these use the same plastic actuator, and they will crack, it's just a question of "when." Search Clutch actuator in the subject search with an author of Hammer and you'll find them. The mod was one of DEET's design, and HE deserves ALL the credit. I haven't even so much as done anything to mine since I did the mod back in 2013 or so.
Hope this helps!
Hammer
04 Dec 2020 00:39 #3
  • Bartman512
Replied by Bartman512 on topic DT2 Clutch Actuator mod
I just ordered one from 2fast moto for a XS650 that supposedly will work with some modification
04 Dec 2020 05:05 #4
  • Bartman512
So I received my XS650 clutch actuator, machined the hole to 1'' to fit the new part in the cover and it fits nicely only thing is the arm that the cable hooks on to is bent the opposite direction, which pulls the cable at a extreme angled position to push the clutch rod. Im wondering if you guys bent the arm the opposite direction? it seems like a pretty heavy gage steel bracket
16 Dec 2020 14:48 #5
Replied by 1971DT250 on topic DT2 Clutch Actuator mod
Post a picture. I discovered in my past research and buying parts that Yamaha had a different actuator with a different offset for one of the early 650 designs.
16 Dec 2020 16:04 #6
  • Bartman512
The only complaint I have with this mod is I cant run anything bigger than a 12 tooth counter sprocket. I installed a 14 and the chain rubs the new actuator. It's obviously bigger than stock.
11 Feb 2021 09:11 #7
Replied by DEET on topic DT2 Clutch Actuator mod
My version doesn't have any limitations and it allows you to still use the outer diamond shaped adjuster cover.
The following user(s) Liked this Post: MarkT, swm
Last edit: 11 Feb 2021 10:11 by DEET.
11 Feb 2021 10:10 #8
Replied by RT325 on topic DT2 Clutch Actuator mod
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=383526401474&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by kingjoel on topic DT2 Clutch Actuator mod
The plasyic gear on my push lever assembly (RT3 part # 214-16340-00-00) is cracked. Is there a solution, if so how can I order one? Thanks!!
Joel RT3 DT250A
03 Mar 2021 12:59 #10
