Rt1 Carb
- kitkatman
Rt1 Carb was created by kitkatman
Hi Everyone, Been a long time since I have been on here so hope I don’t make to big a fool of myself. The carb on my 1970 Rt1 has 275 E1 stamped on the flange,I have read that it should be 275 E4. Am I correct in this, if so what is the difference between the two.The bike runs ok, but I would like to try and get it better. The bike came from Canada to the UK. Any help would be very helpfully. Thanks. Alan.
10 Jun 2024 02:51
Replied by MarkT on topic Rt1 Carb
The "E" number generally denotes jetting specs. First thing to stress is that you must start by identifying exactly what parts are inside your carb before making changes. The calibrated parts work together... so changing one part to match a spec and not the others could result in severe engine damage! It's always a good idea on a new-to-you bike to disassemble carb completely and make sure all the calibrated parts match what they should be.
275E1 (up to engine number 003872) and 275E2 (003873 on) were used in 1970
275E3 specs were only used in "trial production" and not sold
1971 (engine number starting with 009101) got the 275E4 spec.
If the bike runs fine, leave it alone. The difference between the E1 and E2 specs were to correct full throttle richness. The main jet was changed from 240 to 220 AND the 6DP1 needle was raised by moving the clip from the third groove from the top to the fourth groove from the top. (Yamaha stressed that if you go to the smaller main, you must raise the needle.)
The old Clymer manuals probably recommended using 1971 E4 specs on the 1970 model if I remember correctly. The main jet is back at 240 and the slide needle was changed to a 6CF1 with the clip in the second groove from the top. Air screw 1-3/4 turns out from 1-1/2.
And again, best to check all the parts to make sure they are correct. (needle jet was O-4 and pilot jet was 30 in all the above listed specs)
The following user(s) Liked this Post: swm, RT325, Swoop56, Ht1kid, Oldbikenut, Sneezles61
10 Jun 2024 06:46
Oh, and make sure the calibrated parts have the Mikuni "square in the corner of a square" trademark stamped in them. Lot's of carb out there with "rebuild kit" jets and needles in them which are often stamped with the same numbers but have completely different calibrations.
10 Jun 2024 06:56
Replied by RT325 on topic Rt1 Carb
Mark, you're a wealth of knowledge & I didn't know any of that--& I know everything, Not. Thank you for pointing out all these differences.--& possibly saving a piston or worse.
10 Jun 2024 14:49
RT325, I just have the old Yamaha bulletins on some things... and a lot of experience trying things that didn't work out as planned.
The following user(s) Liked this Post: Rick C., RT325, Sneezles61
10 Jun 2024 15:37
- kitkatman
Replied by kitkatman on topic Rt1 Carb
Thank you Mark, your a fountain of knowledge. I have fully rebuilt the bike, and it has just been the finishing touch to it. Now to get out on it when the British summer get’s here. Thanks again Alan.
11 Jun 2024 07:24
- SKYDANCER46
Replied by SKYDANCER46 on topic Rt1 Carb
Mark,
Interesting info,
The 70 RT1 i have has a 275 E4 carb. 220 main, 30 pilot, 6DP1 needle, clip on the 2 from top. 0-4 188 needle jet (nozzle) and a 8.5 mm float height. serial # well below 003872.
I have been looking for a new needle jet. part # 275-14141-34. extremely hard to find.
Wondering if changing out to a 240 main with a 6CF1 slide needle would change things up?
Interesting info,
- Swoop56
Replied by Swoop56 on topic Rt1 Carb
Rob , doing a bit of research , I think the 188 O-4 needle jet in a Suzuki part number is 09494-00082 .
They are likewise , thin on the ground , but CMSNL are listing one in stock . However , before you purchase , it might be wise to confirm it is the 188 O-4 .
The following user(s) Liked this Post: SKYDANCER46
24 Oct 2026 20:22
- SKYDANCER46
Thanks for the info Swoop,
It does look like the Suzuki nozzle at CMSNL is a 0-4 but looking at the picture i see a 72 number on it.
At this point i can not even confirm the 188 nozzle is the original. I assume it is.
Anyone have a 275 E1 or E4 carb laying around and can check the nunbers on the needle jets?
- Swoop56
The CMSNL nozzle photo may be a generic photo , which is why I suggested you check with them first .
25 Oct 2026 12:51
