Measures of Mikuni VM30SS (DT 360 A)
- Gerryz
- Topic Author
Measures of Mikuni VM30SS (DT 360 A) was created by Gerryz
Can anybody give me the outer in- and out-diameter of the above mentioned carb? I have not the original one.... THX!
08 Mar 2024 01:46
Replied by RT325 on topic Measures of Mikuni VM30SS (DT 360 A)
No exactly a VM30ss & now i look closer its just a copy of a mikuni but od & id are probably the same on this same as genuine. Says down in the text bore size 30mm ID & spigot size 40mm OD.
www.amazon.com/Carbman-Carburetor-VM30-8...s%2Caps%2C277&sr=8-5
- Knutco11
Replied by Knutco11 on topic Measures of Mikuni VM30SS (DT 360 A)
I think this is known amongst enthusiasts, but I just wanted to make sure everyone is on board with the Chinese knock-off stuff. Sometimes they can work great, and the money savings will leave you smiling. Other times they are jetted way wrong, and every dimension will be wrong, leaving you without a way to change brass and make adjustments. I've had several leak straight out of the box. I ultimately leave it up to the customer, and explain why cheap isn't always better. Me personally I use genuine used carbs.
13 Mar 2024 06:44
My link up top won't have the oil injection fitting i guess, but was only up there to read the id & od.
Keep looking. All good. In saying 'that', i'd probably use it & find a way to inject the oil as i did once before acvtualy on my DT360A come to think.
Was a Suzuki carb with the pull--push linkage on the side so fed the oil into one of the breather fittings so it dripped into the fuel in the bowl. Worked as it should.
But as i've said before haha--don't do as i do--unless ya really want to!!.
13 Mar 2024 15:54
- Knutco11
Lol, well I guess the oil gets in lol. Albeit effectively bypassing the point of oil injection, but what the heck right? I always thought they needed suction, aka on the engine side of carburetor? I guess the reed ports eliminate that theory, seeing as on those its on the crankcase side, after the reed valve. Either way oil get to motor so I'll shut up now. Nobody cares I know lol, so why won't I shut up? No idea, have a great day!
The following user(s) Liked this Post: RT325, Schu
13 Mar 2024 20:09
- Lizeec
Replied by Lizeec on topic Measures of Mikuni VM30SS (DT 360 A)
On the 1974 DT360A the oil injection line goes from the oil injection pump directly to the cylinder via a banjo bolt fitting, thus no need for a oil injection fitting on the carburetor, the oil injection fitting on the carburetor didn’t start till 1975 on some specific models.
- Gerryz
- Topic Author
Replied by Gerryz on topic Measures of Mikuni VM30SS (DT 360 A)
I found an original one on eBay and asked the seller:
From Airbox to carb is 1.7” or 43.08mm.
From engine to carb is 1.57” or 39.88mm.
Hope to find someone who sells one to Germany….
28 Mar 2024 02:36
