Oil pump still leaks CT1C
Replied by RT325 on topic Oil pump still leaks CT1C
Have you oiled the cable with something dark in color & it’s dripping out down there.
03 Apr 2024 16:12
#71
- Schu
Replied by Schu on topic Oil pump still leaks CT1C
Tom…… put the side cover back on that thing and ride it.
CT1B, CT1C, JT1, JT2, DT360A, GT80B, DT100B, DT125B,
DT175B, DT175C, DT250B, DT400B, Z50, SCR950
The following user(s) Liked this Post: RT325, Sneezles61, Tinkicker
03 Apr 2024 16:12
#72
- Tom P
Replied by Tom P on topic Oil pump still leaks CT1C
Haven't oiled the cable, but did spray some Brakeclean on top of the case, and maybe that loosened up something that flowed down where the tubes enter the case. I've removed the pump a couple of times, and while 2 stroke oil comes out of it when I do, I haven't seen and trans oil leaking through from the other side. My only concern was that the black oil could be mixing with the oil in the pump.
Schu, I've put over 40 miles on it yesterday and today. Testing for leaks is a great excuse to ride
Maybe I'll have to test it one more time today...
03 Apr 2024 16:23
#73
Replied by Ht1kid on topic Oil pump still leaks CT1C
Tom if you owned a pan or shovel head Harley the leaks would drive you crazy
03 Apr 2024 17:07
#74
- Sneezles61
Replied by Sneezles61 on topic Oil pump still leaks CT1C
You’re lucky, snow on the ground up here.. no riding yet… Too cold also?
Sneezles61
Sneezles61
04 Apr 2024 05:41
#75
- Tinkicker
Replied by Tinkicker on topic Oil pump still leaks CT1C
The only possible oil leaking from there would be two stroke oil.
04 Apr 2024 15:28
#76
- Tom P
I'm now pretty sure the black stuff is from when I sprayed some Brakeclean on top of the case, and it flowed into the dead area in the upper right side case, where the 2 autolube tubes come in. Then when riding it heated up and flowed down onto the pump.
The following user(s) Liked this Post: MarkT, Ht1kid, Tinkicker
05 Apr 2024 12:21
#77
- Tom P
One last follow-up. I cleaned the upper "dead area" out with electrical cleaner, and cleaned the pump. Black stuff pooled at the bottom, and I cleaned that out. Nice sunny day today so I rode for 15 miles, and it's completely dry inside. Looks like the new seal under the prime wheel and the HF copper washers are working. Sorry, Harley riders, no drips here
The following user(s) Liked this Post: Ht1kid, Sneezles61, Tinkicker, pahiker
06 Apr 2024 15:23
#78
