Flat slide carb conversion on 75 MX400B
- thumperstew
- Topic Author
Flat slide carb conversion on 75 MX400B was created by thumperstew
Recently got a 75 MX400B. It sat easily 20 years. Working on the fouled stock 38mm Mikuni carb but thought about a flat slide carb. Mikuni TM/TMX or Keihin PWK. What's some thoughts on the conversion. The engine is going in a Champion frame, with low pipe/ oversize air filter. Not a racer though. Thanks
09 Apr 2024 12:24
- LongStride
Replied by LongStride on topic Flat slide carb conversion on 75 MX400B
PWK gets my vote over the TM series, should be able to make smooth power with the kehin
2ET703 Central Texas
The following user(s) Liked this Post: thumperstew
10 Apr 2024 04:17
- turbodan
Replied by turbodan on topic Flat slide carb conversion on 75 MX400B
You could go either way. The PWK seems to be more responsive. The TMX is easier to get jetted crisply and makes better top end on some bikes.
I've always used PWK's on mine, getting them to run crisply at a cruise has always been a challenge.
The following user(s) Liked this Post: thumperstew, LongStride
10 Apr 2024 07:45
- thumperstew
- Topic Author
Replied by thumperstew on topic Flat slide carb conversion on 75 MX400B
Thanks for the suggestions and inputs. Surprisingly, able to get a good cleaning of the stock MX400 VM38 Mikuni. Reinstalled and ran the engine briefly last night, a good thing. Didn't know the engine condition, sounded fairly tight, no bearing noise! Horrible silencer/spark arrestor-loud. I need to repair/replace the intake manifold-excessive cracking. Will probably clean it then seal temporarily to continue motor testing. Any suggestions on a replacement or another option? Has anyone done a 3D printed replacement? I have found NOS manifolds-$100+. This engine is going into a Champion YAM3 chassis so have a little flexibility.
08 May 2024 09:20
