New cylinder head gasket needed?
- jmagda
- Topic Author
New cylinder head gasket needed? was created by jmagda
I am replacing my DT3's points (a no-spark issue in another post on here) and it looks like I will have to reset/check TDC again. Will I have to replace the cylinder head gasket, which is brand new and has never experienced this engine having been run with it? The manual says every time you take off the cylinder head to replace the gasket.
08 May 2024 07:45
Replied by Gr8uncleal on topic New cylinder head gasket needed?
Try it and see.
If it seals, then good. If it blows, then replace it.
Shouldn't apply to your nearly new one, but some folks anneal and re-use their old ones.
08 May 2024 07:58
Replied by Ht1kid on topic New cylinder head gasket needed?
I agree with AL I would reuse it if you have some copper coat spray some on your gasket
08 May 2024 08:35
Replied by MarkT on topic New cylinder head gasket needed?
If it's copper, generally can be reused. Annealing also generally wouldn't hurt if copper.
08 May 2024 08:39
- jmagda
- Topic Author
Replied by jmagda on topic New cylinder head gasket needed?
Yes, it's copper. Thanks, guys.
08 May 2024 09:11
Replied by RT325 on topic New cylinder head gasket needed?
Not old style copper asbestos sandwich that they used to be?. Solid copper?.
08 May 2024 14:57
- jmagda
- Topic Author
Don't know about that. It was from Yambits, GSK163, kind of a puffy copper gasket.
09 May 2024 05:19
Ok, so its this one. I wouldn't anneal it as will just be thin copper over asbestos. Maybe not asbestos in the modern age but something sandwiched in between.
I just grease them & refit them.
I do anneal solid copper though. That's my thought anyway.
yambits.co.uk/dt1cmx-cylinder-head-gasket-p-138498.html
- jmagda
- Topic Author
Yep, that's the one. Oh. Grease? Didn't know about that.
It's just what i do & 'i think' it lets them squash up tight. Just a theory but works for me.
09 May 2024 06:35
