Re:76 YZ400 compression PSI
- Judohead
- Topic Author
76 YZ400 compression PSI was created by Judohead
I'm rebuilding a 86 YZ400. I've got fire, gas, and air. It just feels low on compression for a 2-stroke 400. Does anyone know the stock compression PSI. I can't seem to find it anywhere.
Sent from my C6930 using Tapatalk
27 Oct 2023 11:12
Replied by Gr8uncleal on topic 76 YZ400 compression PSI
I'm not familiar with that model. However, I would observe that it is fitted with a decompression valve linked to the kick start, so that will have an effect on what you're feeling when you kick it over. Unless, of course, it's been disconnected.
I'm not sure that compression figures were published by Yamaha.
- akara1
Replied by akara1 on topic 76 YZ400 compression PSI
with the decompressor cable removed and the valve not leaking, it should be 140-160psi on a healthy engine, tested with a small engine compression tester. 120psi rings tired, 100psi or less top end refresh time.
27 Oct 2023 14:03
- Sneezles61
Replied by Sneezles61 on topic 76 YZ400 compression PSI
Is compression to be tested on a cold engine?
Sneezles61
Sneezles61
27 Oct 2023 14:32
Replied by MarkT on topic 76 YZ400 compression PSI
There's way too many variables (the gauge used is a biggie, factory two stroke gauges are very expensive but probably most accurate on these engines) to what readings you get vs what someone else will get with a different technique, etc.
Probably why Yamaha never published specs?
27 Oct 2023 14:41
- Judohead
- Topic Author
Replied by Judohead on topic Re:76 YZ400 compression PSI
Well, I didn't have but 30 PSI. Decompression is unhooked. I got the top end off, thankfully the bore looks good, and bottom rod bearing is still good. Head is a little rough, going to get it polished, and a new top end.
27 Oct 2023 15:44
Replied by MarkT on topic Re:76 YZ400 compression PSI
Sounds odd if bore looks good? Hope you still don't have 30 psi after rebuilding top end due a very inaccurate gauge reading or something.. (Been there, done that)
Do you have access to another similar two stroke you could try the gauge on?
27 Oct 2023 16:48
- Judohead
- Topic Author
Replied by Judohead on topic Re:Re:76 YZ400 compression PSI
Yeah, tried the Guage on my Husky 125, it was reading close. I'm not sure how long this bike has sat up. Hopefully I'll get it cranked after a top end.
Sent from my SM-T970 using Tapatalk
27 Oct 2023 17:03
125 was reading close to what?
27 Oct 2023 17:19
- Judohead
- Topic Author
It was close to factory spec. A little low, but it's been awhile since a top end on it.
27 Oct 2023 17:37
