Conversion of DT 125 to DT 175. Year 1977
- daniel-jaros
- Topic Author
Conversion of DT 125 to DT 175. Year 1977 was created by daniel-jaros
Year 1977
So I finally got the cylinder and head from ebay.
Can you please advise me what all needs to be changed during the rebuild?
I know there are other parts.
1. Piston pin bearing.
2. Chip 160
3. Another needle?
4. Freewheeling chip?
I have a cylinder from an AG 175 in the exhaust channel there is a small hole from the cylinder to this channel.
Is it because of reduced performance?
Furthermore, the head does not fit the cylinder, what type of head should I look for?
Thank you Daniel
Year 1977
2. Chip 160
3. Another needle?
Thank you Daniel
17 Jun 2023 12:45
- Yamfan
- User is blocked
Replied by Yamfan on topic Conversion of DT 125 to DT 175. Year 1977
You need a DT or CT175 head. Be careful not to get a head with 6 boltholes, they are for later motors.
17 Jun 2023 12:49
- daniel-jaros
- Topic Author
Replied by daniel-jaros on topic Conversion of DT 125 to DT 175. Year 1977
Cylinder And head
17 Jun 2023 13:34
Replied by RT325 on topic Conversion of DT 125 to DT 175. Year 1977
Small hole in exhaust channel is just to make starting easier on the old Ag's.
Nothing to do with performance, well, reduce it if anything.
17 Jun 2023 18:07
Images of a "77 parts are a bit difficult to pin down & goes from "76 to "78 wherever i look.
But if yours has the big base & not using the long studs then it'll need the 6 stud head.
If i'm understanding the story!!.
17 Jun 2023 18:32
