1974 GT80A front forks
- principal282
- Topic Author
1974 GT80A front forks was created by principal282
I have my forks apart, cleaned, ready for seals.one problem.the two inner tubes seem slightly different. Also, a thin tiny tube came out of one, but not the other one!! If it is in there, it may be rusted to the inner wall.see pics. Washers were not too happy to come out either.what makes r and L different ? Do both sides use a spacer tube?
see link for photo
imgur.com/gallery/pTiyZzW
see link for photo
Replied by RT325 on topic 1974 GT80A front forks
I can only go by partzilla which isn't easy to follow but shows two springs so i'd think there'd be two long preload spacers but shows fork tube 'stansion' as 7 & 8 different numbers plus yours look like a bush or something on the right one near the bottom but not 'at' the bottom. I''m useless sorry. I guess you've looked on partzilla or similar.
www.partzilla.com/catalog/yamaha/motorcy...nt-fork-front-fender
28 Jul 2023 20:48
- principal282
- Topic Author
Replied by principal282 on topic 1974 GT80A front forks
Yes looked there and also the factory service book.
I am soaking er in pb blaster on the inside hopefully she comes free thanks!!
28 Jul 2023 21:04
- principal282
- Topic Author
I know there is a tube there. I can drop the cleaned up tube in one she goes all the way. In the other one she stops about 7!inches short. Any great ideas how to free the bugger??
29 Jul 2023 06:58
- dubepj
Replied by dubepj on topic 1974 GT80A front forks
Doing same job on mine. Took apart long time ago. Forgot to label left and right. Can some one help me identify which is which?
09 Aug 2023 09:27
Replied by MarkT on topic 1974 GT80A front forks
"Doing same job on mine. Took apart long time ago. Forgot to label left and right. Can some one help me identify which is which?"
One lower has a brake lug. Front brake is on the left side sitting on the bike.
The following user(s) Liked this Post: Ht1kid, principal282
09 Aug 2023 10:11
- dubepj
Thanks for reply MarkT. I'm aware of the Brake lug on the left side.
My concern is the sliders that go inside the fork leg. They are different. One is a bit longer. i think the shorter on is on the right side as the oil capacity is more on that side. (96 ml on Left and 120 ml on right)
Please correct me if I'm not right. Thanks
10 Aug 2023 07:35
- dubepj
Next question
I believe fork seals are 26 MM x 37 MM x 10.5 MM ordered some but Amazon says I can get refund. If that's correct size I'll try local seal store.
10 Aug 2023 07:54
Replied by Ht1kid on topic 1974 GT80A front forks
You need to go by the numbers on the seal be sure to take them with you so they can get the correct seals for you
10 Aug 2023 15:37
Is there a difference in the position of the lower bush on the fork tube between left & right--can't think why, but show different numbers between 8 & 7, so does 7 pic give a clue because 8 is hidden. Mystery.
10 Aug 2023 16:49
