Thermal Flow Shock Rebuild
Replied by BruceeD on topic Thermal Flow Shock Rebuild
Ahh thanks, not sure how I missed those
15 May 2020 19:17 #41
Replied by Tjlee on topic Thermal Flow Shock Rebuild
The holes I am referring to are in the cylinder valve. They measure 3/64" / 1.19mm
Attached some pictures.
17 May 2020 11:42 #42
Yep my YZ125 has those then the shaft has a hole that goes up a bit then a hole drilled through the side of the shaft to intersect that hole.
17 May 2020 15:32 #43
Replied by Le7316 on topic Thermal Flow Shock Rebuild
So i will need two of these on each side of the shocks and thats it for the whole rebuild process ? or there are other seals that i need to purchase ? Can someone confirm ?
Seal - AVX Part # TC12X23X7
19 Aug 2022 07:26 #44
Replied by MACE6772 on topic Thermal Flow Shock Rebuild
You will also need 2 O rings. One large one for the reservoir cap and one small one inside the inner tube. They are metric sized. If you go to the Tech section and read " how to rebuild Thermal Flow shocks", I list the part #s and contact info for my source. I do not know how to translate the part # into a size. If you did not use heat to get the cap off, the large O ring will probably be OK to reuse. The article includes 2 pictures that show the small o ring and it's position on the shaft.
The following user(s) Liked this Post: MarkT, Snglsmkr, Ht1kid, Le7316
19 Aug 2022 17:38 #45
Could you post a link here ? I see the "How to Articles" under Tech Library but didnt see your post that you mentioned.
22 Aug 2022 08:10 #46
QUOTE " Oem stock bushings- 1M1-22216-00-00 come up on Flea bay sometimes. OEM part # 275-22123-00 will work but needs to be narrowed to .782" to fit. Don't forget Part # 90106-10025-00, These are the slightly longer OEM shock bolts you will need for the top if you are installing a luggage rack.
I BUY THERMAL FLOW SHOCKS"
MACE6772 ,
Do you happen to have the dimensions of the stock bushings of these shocks ?
Last edit: 26 Aug 2022 06:59 by Le7316.
26 Aug 2022 06:49 #47
Replied by RTD2 on topic Thermal Flow Shock Rebuild
Found out the hard way today that the MX Thermal Flow seals are not 23mm they are (I hope) 28mm OD.  I hope that helps someone else.
68 DT1; 70 DT1C MX; 71 CT1C; 71 RT1B; 71 DT1E MX; 73 AT3MX, 73 MX360, 76 Honda Elsinore; 2021 KTM 500 EXC-W; 2001 Honda XR400R; 2007 Harley Davidson Sportster 1200; 2015 Ducati Scrambler Full Throttle
02 Sep 2022 19:24 #48
Replied by automan on topic Thermal Flow Shock Rebuild
RTD, where to find those 28mm seals?
cliff
03 Sep 2022 04:10 #49
Show:Not hidden
See orders from:Last 60 DaysFilter by:AllORDER DATESep 02, 2022ORDER NUMBER11-09054-65685SOLD BY irvinemanuser ID, click for member’s profile ORDER TOTALUS $31.96
Leave feedbackAVX Shaft Oil Seal TC12x28x6 Rubber Lip 12mm/28mm/6mm metric
(361455648663)
Quantity : 2Estimated delivery Wed, Sep 7 - Thu, Sep 8
PAID
Not yet shipped
Feedback needed
No Feedback receivedITEM PRICE:US $29.90
03 Sep 2022 07:40 #50
