2-cycle fuel oil selection
- 2-smoker
- Topic Author
Replied by 2-smoker on topic 2-cycle fuel oil selection
Would you go along with the 32:1 ratio then?
15 Jul 2023 12:41
#11
Replied by MarkT on topic 2-cycle fuel oil selection
32:1 is what I use on my premix bikes
15 Jul 2023 12:59
#12
Replied by Ht1kid on topic 2-cycle fuel oil selection
MarkT one last question it says it smells like castrol oil is that castrol R. I liked that smell but sure was a dirty oil
15 Jul 2023 13:14
#13
I ran Castrol R40 at 16:1 racing in the 70's. Best lubrication at the time. Nasty stuff though.
The legend oil is not dirty. Exactly the opposite. Burns very clean. (I can't say that I've noticed a "castor smell" from it... the stuff I have seems pretty much odorless)
15 Jul 2023 13:52
#14
- Yamfan
- User is blocked
Replied by Yamfan on topic 2-cycle fuel oil selection
Be aware that low smoke 2T oils are not likely to protect motors, as well as oils without low smoke additives. That's according to testing outlined in a Yamaha Motor Co, technical paper, and probably explains why main bearing and big end wear, on vintage 2T motors, seems to be something that occurs much faster now, than way back, when there were no low smoke oils.
16 Jul 2023 01:42
#15
Apples and oranges. The Yamaha paper is about old technology "low smoke" oils with additives to minimize smoke that inhibit lubricity.
And here we go down the "oil thread" rabbit hole... I should have known better than to post a suggestion.
The following user(s) Liked this Post: asco, Schu, Ht1kid, Tinkicker
- Yamfan
- User is blocked
Polybutene is the main smoke reducing additive still being used today. The main issue is that PB is very thick, which means 2T oils intended for use in injection systems contain up to 20% solvent (by volume), which reduces lubrication performance even more.
16 Jul 2023 09:01
#17
MarkT in glad you told us about Legend oil I’m going to start using it and also about Autolite plugs in my opinion they are better than NGK
16 Jul 2023 09:51
#18
- asco
Replied by asco on topic 2-cycle fuel oil selection
MarkT
Oil threads can indeed be frustrating but because you’re here more than most “if a new person is asking a question it is our collective responsibility to try to welcome them into the group. Please keep an eye open for abuse of privilege here because we want new people to get just enough special attention so they don’t feel we’re Yama-Snobs.”
thank you all
asco
thank you all
asco
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
16 Jul 2023 10:19
#19
- 2-smoker
- Topic Author
Thanks for that consideration, MarkT. I actually have a 1971 Yamaha DT1-E that I will be starting a 'restoration' on and I'm sure this all applies there too. But first I've got to get my Honda MR250 Elsie on the road. Do you have any advice as to obtaining some of this ZX-2R oil? I'm having a hard time finding it or a a source via the internet searching - and I don't need the 4 gallons that seems to show up...har, har.
16 Jul 2023 10:50
#20
Moderators: Makotosun
