DT front wheel and brake hub
  • Zedbed
  • Zedbed's Avatar Topic Author
DT front wheel and brake hub was created by Zedbed
Hello all!
I've just bought a front wheel for a DT. The wheel is 19" the brake drum is approx 150 mm. inside the drum below the Yamaha symbol is the number 22700.
My question is: is this a DT250,DT400 or either or neither!
Thanks in advance
08 Mar 2024 06:27 #1
Replied by Gr8uncleal on topic DT front wheel and brake hub
Could you post a clear picture of the numbers cast on the inside? You'll need to use Imgur or similar.
08 Mar 2024 06:30 #2
Replied by Ht1kid on topic DT front wheel and brake hub
Greetings from Tennessee.
08 Mar 2024 07:59 #3
  • Zedbed
Replied by Zedbed on topic DT front wheel and brake hub
How's that? did that work?
I see my photo didn't arrive, I'll have to wait for the web site  to get repaired and then try again.
Sorry and all that !
Last edit: 08 Mar 2024 09:13 by Zedbed.
08 Mar 2024 08:59 #4
Replied by Schu on topic DT front wheel and brake hub
I’m thinking neither, because my DT250 and 400 both have 21 inch front wheels.
CT1B, CT1C, JT1, JT2, DT360A, GT80B, DT100B, DT125B,
DT175B, DT175C, DT250B, DT400B, Z50, SCR950
08 Mar 2024 09:03 #5
  • Zedbed
I read it somewhere yesterday that 19" was an option, but it didn't say which model.
The brake drum is a bit larger than the DT 175 and a wider rim (3.25 -19 tyre or tire in the USA!) .
My DT 175 has a 21"front wheel.
08 Mar 2024 09:30 #6
Just had a ferret around on the CMSNL website and it looks like you might have a front wheel for a 1973 DT3/RT3.
Looks like that 227 hub was used on the enduro 250 and 360 bikes from 1968 to 1974 and the DT3/RT3 had a 19" front wheel. Looks like the 1974 DT250/360 had a 21" front wheel.
08 Mar 2024 09:56 #7
