1976 DT250 wiring
- Monster
- Topic Author
1976 DT250 wiring was created by Monster
Hi everyone I am new here and am new to working on DT’s always wanted one when I was a kid ran across one in pretty nice shape but the wiring was hacked up can someone tell me if a harness from a 1974 DT360 will work on a 1976 DT250 ?
17 Aug 2019 06:22
- DEET
- Moderator
Replied by DEET on topic 1976 DT250 wiring
Some of it will work. But the ignition won’t since the DT360 uses a CDI and the DT250 used points.
I make new wiring harnesses. I also make an adapter that allows a points ignition to be used on a DT360.
The following user(s) Liked this Post: malcoops
17 Aug 2019 06:44
Replied by MarkT on topic 1976 DT250 wiring
Could it be made to work? Probably. One big difference is 360 had CDI and 250 has points.
It wouldn't be worth the hassle to me unless maybe it was free and I had the time to figure it out and not enough $ to get the correct one.
I'd contact member DEET here... he makes new harnesses for most models. Much better than messing with old used or even "NOS".
DEET's email: This email address is being protected from spambots. You need JavaScript enabled to view it.
17 Aug 2019 06:45
Oops. Typed too slow again!
17 Aug 2019 06:47
- DEET
- Moderator
Funny how that happens!!!
17 Aug 2019 07:17
- Mothersbaugh
Replied by Mothersbaugh on topic 1976 DT250 wiring
DEET saves you dollars, but not your fingers?
17 Aug 2019 15:58
- Monster
- Topic Author
Replied by Monster on topic 1976 DT250 wiring
Thanks guys I will contact Deet Thanks again
17 Aug 2019 16:17
Replied by Gr8uncleal on topic 1976 DT250 wiring
DEET
How much are the adapters and do you have a photo that you could post?
Thanks.
Alan
18 Aug 2019 00:52
- DEET
- Moderator
The adapter harness isn’t expensive.
I stopped posting photos of my designs because there are folks out there that are stealing them. Then they exploit it for their financial gain.
The following user(s) Liked this Post: Blackhat250
18 Aug 2019 06:04
Fair enough
Re cost, obviously I need to take into account postage (plus any taxes) to the UK.
18 Aug 2019 11:27
