DT125 left and right signals light at the same time
Replied by MarkT on topic DT125 left and right signals light at the same time
Gr8uncleal wrote: "I've repaired quite a lot of these old switches and test the circuitry by attaching my test lamp, via a battery, to the brown/white wire terminal and each of the dark brown and dark green in turn. When working correctly, each side only lights up when the switch is in that position."
Yes, what you said is true IF you are testing just the switch. It would not be true with the switch connected to the wiring harness and probing the wires where the signals connect on the bike.
01 May 2024 11:18
#11
I went back and read my original answer in this thread and changed the wording around as it wasn't as clear as it could have been. *I* knew what I meant though!
I've had this same puzzling thing happen to me many years ago and spent a long time chasing my tail trying to figure it out... which I finally did. It's simply the way the indicator light in the gauge is wired so that the little bulb grounds through the the filaments of the opposite side signal lights. Genius wiring but confusing as heck when probing the harness with a test light
01 May 2024 11:31
#12
Replied by Gr8uncleal on topic DT125 left and right signals light at the same time
Yes Mark, testing my repaired switches only, on the kitchen table!
01 May 2024 11:31
#13
- Clegg
- Topic Author
Replied by Clegg on topic DT125 left and right signals light at the same time
Mark is the winner ding ding ding ding! I was thinking about this last night and thought about the gauge indicator bulb being for left and right signals. I removed that and the power went where it was supposed to go. I now have 4 working signals on this bike!
I knew it had to be something simple because there was no hacked up wiring on the bike.
I am also using all incandescent bulbs.
1971 SL350, 1973 Bultaco Matador, 1978 XS650, 1979 MX175, 1982 XT250, 1982 GS650, 1982 CB450T HAWK, 1979 IT175, 1977 Suzuki TS185
