1974 DT360 Disassembly and Restoration
- pabdt
- Topic Author
Replied by pabdt on topic 1974 DT360 Disassembly and Restoration
Oh boy, just got the rear swing arm off. The zirc fitting is 45 years clean. Swing arm practically stuck in one position.
Rear tail light assembly is destroyed. Guy used JB weld to put it together. As I disassemble this bike, I see that only at the deepest level am I finding stock bolts. Rear fender dented but repairable.
Can't believe this bike has great spark. He did put a new source coil on it before I got it. Which way do I turn that bolt to remove the magneto? Left to loosen, right tighten?
Good news is motor has virtually no vertical moving on rod and I tested trans, so I will probably not split the engine.
Plan to replace seals and clean up everything else though. Thinking 12v replacement setup.
74 DT 360 ... resto in progress.
Replied by Gr8uncleal on topic 1974 DT360 Disassembly and Restoration
Pretty sure that's a standard right hand thread, so left to loosen.
The flywheel/magneto centre has a left hand thread in it (probably 27mm) and it is standard practice to use a flywheel puller to remove it.
- pabdt
- Topic Author
the frame and swing arm appear in good condition and straight but the bars are gone
note to self, apply grease to shaft even though no contact points. Should this be generally packed w/grease to drain to lower ball bearings?
bike born in 73. numbers match frame and engine. #446-004427
where can I get a replacement decal like this?
Replied by MarkT on topic 1974 DT360 Disassembly and Restoration
DEET for the decal.
I recommend checking rod big end bearing by correct procedure in service manual...
Compression might have been low due to compression release if it was working or leaking.
31 Aug 2019 15:03
#14
- pabdt
- Topic Author
CR not connected during testing. I'm leaning towards tearing it apart for inspection. At a min, I'll check out that procedure. Thanks.
31 Aug 2019 17:16
#15
- Snglsmkr
Replied by Snglsmkr on topic 1974 DT360 Disassembly and Restoration
The flywheel nut is certainly a righthand thread. There is a close fitting washer under it that needs to be slid off the crankshaft before the puller is installed in the flywheel.
It is not unusual for moisture in the crankcase to cause corrosion of the crank bearings. Does the crank rotated smoothly? If not they may need replacement.
31 Aug 2019 18:30
#16
- pabdt
- Topic Author
hub/bearings appear in good shape. need to inspect closer especially seals.
pulled apart rear wheel today. plan is bead blast, polish, new spokes. trying to decide if I want to keep these wheels or put some Excel rims on it. Will know more after cleaning/polishing them.
before disassembly
before disassembly
- pabdt
- Topic Author
starting cleaning the head today...found a chip in fins I didn't see before. anyone have a spare head? I can always install and use it until I find one.
can see where someone had previous went in and scrapped up the combustion chamber, though not bad.
03 Sep 2019 18:45
#18
- Schu
Replied by Schu on topic 1974 DT360 Disassembly and Restoration
I had the same thing on my 360. I just reshaped the broken fin.
CT1B, CT1C, JT1, JT2, DT360A, GT80B, DT100B, DT125B,
DT175B, DT175C, DT250B, DT400B, Z50, SCR950
The following user(s) Liked this Post: MarkT, Badger52, Snglsmkr, pabdt, darinm, Super90
04 Sep 2019 03:54
#19
- pabdt
- Topic Author
nice sculpturing Schu... I may be able to do the same.
Update: working on cleaning the frame for paint and bead blasted a small section of the hub to see what it would look like.
Hub looks great. Think I will be polishing the hubs fully though.
Can one you guys w/a 360 look at the right foot peg(frame inverted) and tell me if the weld angle looks correct. Also, kickstand bracket looks twisted.
