How to remove bearing from push lever axle?
- Gerryz
- Topic Author
How to remove bearing from push lever axle? was created by Gerryz
I ordered new bearings and oil seals for my DT 360A (1974) project and removed all old bearings and oil seals. Only the bearing from the push lever axle I can not remove. Any idea? There is no special tool in the service manual.
23 Apr 2024 14:15
- LongStride
Replied by LongStride on topic How to remove bearing from push lever axle?
Push lever = clutch actuator arm? , Small bearing puller and some heat, is it bad ? if not leaving it might be an option?
2ET703 Central Texas
23 Apr 2024 16:00
Replied by RT325 on topic How to remove bearing from push lever axle?
I'd leave it alone unless necessary. Otherwise might be able to pick the rollers & cage out & get something under the top lip. Sounds dodgy though if it went wrong.
23 Apr 2024 16:26
- MikeK-uk
Replied by MikeK-uk on topic How to remove bearing from push lever axle?
If we are talking about the small needle roller bearing inside the gearbox case next to the clutch rod actuator/pivot, i broke two small pullers and ruined the bearing trying to get it out.
A machine shop had to do it for me.
Mike
Mike
24 Apr 2024 12:31
Just want to be sure ya not talking #11 in first link & am talking #24 in second link.
www.partzilla.com/catalog/yamaha/motorcy.../dt360a/transmission
www.partzilla.com/catalog/yamaha/motorcycle/1974/dt360a/clutch
- run103
Replied by run103 on topic How to remove bearing from push lever axle?
you need a blind bearing puller
24 Apr 2024 14:44
- Gerryz
- Topic Author
Replied by Gerryz on topic How to remove bearing from push lever axle?
thx god a friend of mine has a set of blind bearing pullers (thx for the tipps!!) to get out this damned bearing. NO PROBLEM with the puller. Work is done. Now all parts will be cleaned and get a glass beads blasting (don't know if this is the correct English designation).
The following user(s) Liked this Post: LongStride
29 Apr 2024 11:14
