1971 Yamaha DT1-E 250 Enduro YamaLube Oil Pump
- 2-smoker
- Topic Author
1971 Yamaha DT1-E 250 Enduro YamaLube Oil Pump was created by 2-smoker
I just acquired this bike with an engine that has been torn down a bit with the oil pump removed and completely disassembled. I'm attaching a picture and don't know yet if I actually have all the pieces. My question is if I can simply keep it entirely removed and go ahead and run pre-mix - or does the assembled pump still have to stay in place for some reason?
09 Aug 2023 13:59
Replied by MarkT on topic 1971 Yamaha DT1-E 250 Enduro YamaLube Oil Pump
Best practice is to remove the pump driveshaft and buy or make a block-off plate for the hole in the clutch cover. Driveshaft bushing is lubed by autolube pump oil. Clutch cover may need to be removed to remove pump driveshaft.
Then you can premix. If you don't remove the shaft, it can seize... not good. That said, if you just want to start the bike and run it a little, it won't hurt to leave the driveshaft in place temporarily without a pump... I just wouldn't do it long term and maybe try to oil the bushing a little.
ebay block off plate
- asco
Replied by asco on topic 1971 Yamaha DT1-E 250 Enduro YamaLube Oil Pump
I like running oil pumps.
asco
asco
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
09 Aug 2023 18:32
- asco
If you’re going to go to all the trouble to remove the clutch side cover, drain the oil, put a new side cover gasket on, after thorough cleaning, it makes sense to me, if you already have the drive gear in place that runs off the primary gear, to get yourself a pump and connect it. Along with the splitter for the throttle cable on the oil pump, a couple of banjo fittings. And, if you’re really concerned that the pump might fail, add some two-stroke oil to your gas tank, which will prevent rust as a back up.
Asco
Asco
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
- msavitt
Replied by msavitt on topic 1971 Yamaha DT1-E 250 Enduro YamaLube Oil Pump
I love the yamalube pumps, both at the gas station and how bike runs.
its a very clever device that works great, prefer over premix
The following user(s) Liked this Post: MarkT, Swoop56, asco, Ht1kid, Sneezles61
10 Aug 2023 11:05
- 2-smoker
- Topic Author
Replied by 2-smoker on topic 1971 Yamaha DT1-E 250 Enduro YamaLube Oil Pump
Following up on this - I am for the time-being, going to run the bike without the pump... using a block-off plate, etc. I have been running Lucas semi-synthetic 2-stroke oil mixed at 1:32 in my '76 MR250 Elsinore - and assume this would be a good mix ratio in this DT1-E 250?
06 May 2024 16:31
