Oil seal ?
- ajhuxley
Replied by ajhuxley on topic Oil seal ?
Hi Mark
I need a left crank seal for my 1980 DT175 after a main bearing replacement, about 4 years ago I used an IT175 double lip seal - 9310225258 but now the same Yamaha supplier is saying they are no longer available. Do you have a different part number I can try?
Cheers
Cheers
1980 DT175mx - 99% original
1981 RD350LC - restored
1980 CB750fa - restored
1982 GS550Ez - winter hack
17 Apr 2024 10:02
#11
Replied by Gr8uncleal on topic Oil seal ?
CMSNL have them in stock.
Postage will sting, but not as bad as from the US.
The following user(s) Liked this Post: MarkT, ajhuxley
17 Apr 2024 10:18
#12
Replied by MarkT on topic Oil seal ?
I don't recognize that number? Same seal as 77-79 IT175
Left (ignition) side is 93103-25125-00
The following user(s) Liked this Post: ajhuxley, Ht1kid
- ajhuxley
Cheers, saw 1 left on csmnl but as you say postage is a killer. Got it from Fowlers last time but now unavailable
- ajhuxley
cheers, that number is replaced by the number I used and is no longer available. I'll try another UK Yamaha dealer but looks like I might have to go with a std DT175 seal :(
Very odd. I checked and several US dealers still sell it brand new (many times in stock) under the 93103-25125 part number. Including CMSNL!
www.cmsnl.com/yamaha-it175-1977-usa_mode...seal-5v6_9310325125/
18 Apr 2024 07:16
#17
It also looks like you can get the All Balls 24-1073 crank bearing and seal kit in the UK which has the KOYO bearings and OEM seals... about £40
18 Apr 2024 07:22
#18
- ajhuxley
Thanks for all the info, appreciate it and seems like Ill be able to get the IT seal from other places, weird that Fowlers say its no longer avaialble.
Koyo bearings are only £12 for a pair so it makes sense to buy seals individually.
18 Apr 2024 11:35
#19
Make sure you get the correct internal clearance rating on the bearings... C3? I'd have to look it up.
18 Apr 2024 12:04
#20
