How to remove bearing from push lever axle?
  • Gerryz
  • Gerryz's Avatar Topic Author
I ordered new bearings and oil seals for my DT 360A (1974) project and removed all old bearings and oil seals. Only the bearing from the push lever axle I can not remove. Any idea? There is no special tool in the service manual.
23 Apr 2024 14:15 #1
Replied by LongStride on topic How to remove bearing from push lever axle?
Push lever = clutch actuator arm? , Small bearing puller and some heat, is it bad ? if not leaving it might be an option?
2ET703 Central Texas
23 Apr 2024 16:00 #2
I'd leave it alone unless necessary. Otherwise might be able to pick the rollers & cage out & get something under the top lip. Sounds dodgy though if it went wrong.
23 Apr 2024 16:26 #3
Replied by MikeK-uk on topic How to remove bearing from push lever axle?
If we are talking about the small needle roller bearing inside the gearbox case next to the clutch rod actuator/pivot, i broke two small pullers and ruined the bearing trying to get it out.
A machine shop had to do it for me.
Mike
24 Apr 2024 12:31 #4
Just want to be sure ya not talking #11 in first link & am talking #24 in second link.
www.partzilla.com/catalog/yamaha/motorcy.../dt360a/transmission
www.partzilla.com/catalog/yamaha/motorcycle/1974/dt360a/clutch
Last edit: 24 Apr 2024 14:41 by RT325.
24 Apr 2024 14:41 #5
Replied by run103 on topic How to remove bearing from push lever axle?
you need a blind bearing puller
24 Apr 2024 14:44 #6
  • Gerryz
Replied by Gerryz on topic How to remove bearing from push lever axle?
thx god a friend of mine has a set of blind bearing pullers :) (thx for the tipps!!) to get out this damned bearing. NO PROBLEM with the puller. Work is done. Now all parts will be cleaned and get a glass beads blasting (don't know if this is the correct English designation).
The following user(s) Liked this Post: LongStride
29 Apr 2024 11:14 #7
