DT 250B Damper strap , what is it good for ?
- Wessi
- Topic Author
DT 250B Damper strap , what is it good for ? was created by Wessi
Just a small detail, but raises questions to me.I found rubber fragments on the frame of my restoration project, located under the seat. Tried to cut one from 3mm rubber sheet, but what is it damping?Part number 276 14747-00Does it hold cables, or damping the seat, when wide open?
Part 42 in this diagramm www.cmsnl.com/yamaha-dt250-1976-usa_mode.../partslist/D-01.html
Thanks for your ideas.
imgur.com/UIxdqhX
imgur.com/UIxdqhX
28 Mar 2024 00:15
- Schu
Replied by Schu on topic DT 250B Damper strap , what is it good for ?
This is the best 250B under seat photo I have in my archives and I’m not seeing it anywhere. I will check under the seat on both of mine later today and see if they have one. Both of mine are unrestored so they may still be there.
imgur.com/a/IMJHSJs
imgur.com/a/IMJHSJs
CT1B, CT1C, JT1, JT2, DT360A, GT80B, DT100B, DT125B,
DT175B, DT175C, DT250B, DT400B, Z50, SCR950
The following user(s) Liked this Post: Wessi
- Schu
Both of mine still have that rubber damper and it is what you assumed. The rim of the seat pinches that rubber band when the seat is fully open. The band slides to the right or left along the frame tube.
imgur.com/a/YcpISWC
3 photos to scroll thru
imgur.com/a/YcpISWC
The following user(s) Liked this Post: MarkT, Wessi, Ht1kid, LongStride
- LongStride
Replied by LongStride on topic DT 250B Damper strap , what is it good for ?
None of my bikes have it, part diagram calls it a muffler damper?
2ET703 Central Texas
28 Mar 2024 08:46
- Schu
Muffler damper?
The muffler is on the opposite side of the bike.
28 Mar 2024 10:05
Replied by Gr8uncleal on topic DT 250B Damper strap , what is it good for ?
"Muffler damper?
The muffler is on the opposite side of the bike."
It is a part that was first used on an earlier bike, the 1969 HT1 (model code 276) and this is likely the function on that bike. Yamaha often didn't change the name of a part, even if it was used for a different function on a later bike.
The following user(s) Liked this Post: MarkT, Swoop56, Schu, Wessi, Ht1kid
28 Mar 2024 10:46
Replied by MarkT on topic DT 250B Damper strap , what is it good for ?
Alan beat me to it, I just typed a similar answer, it was used to dampen muffler on earlier models like my LT2.
The following user(s) Liked this Post: Snglsmkr, Schu, Wessi, Ht1kid
28 Mar 2024 10:49
