Foam under the seat that protects battery top
- jmagda
- Topic Author
Foam under the seat that protects battery top was created by jmagda
New seat, battery and protective foam squares. But the foam square glued to the seat pan (that when the seat is down, rests on top of the battery) has this strip of brownish, oily something that runs the width of the battery. The oily strip aligns to where I'm pointing to in the second photo. Any ideas what this oily stuff is or where it's coming from? Is it battery acid? Fumes from battery acid? Is there danger it will eat into my beautiful new seat pan? The battery itself is not oily like this.
www.flickr.com/photos/94364593@N00/shares/k1u5GcW7s1
flic.kr/p/2pLpQPn
flic.kr/p/2pLpQPn
- 1971DT250
Replied by 1971DT250 on topic Foam under the seat that protects battery top
Is the vent tube blocked or pinched?
21 Apr 2024 06:36
- jmagda
- Topic Author
Replied by jmagda on topic Foam under the seat that protects battery top
Negative. Runs down and out past the swing arm.
21 Apr 2024 07:18
- pahiker
Replied by pahiker on topic Foam under the seat that protects battery top
Was the battery cleaned before being installed? Maybe it was pre existing and the foam just picked it up. Does the stain have an odor?
1973 Yamaha RT3
2024 Suzuki DR650
2024 Suzuki DR650
21 Apr 2024 07:24
- jmagda
- Topic Author
Battery was new when installed and clean. The stain used to have a faint gasoline-y smell, but not anymore.
21 Apr 2024 07:34
Replied by MarkT on topic Foam under the seat that protects battery top
Maybe oil cap was set on battery during fill and foam absorbed some oil left behind?
If you're concerned it's acid... mix a little baking soda in a little water and apply it to the foam... if it bubbles up it's acid. But it really looks like an oil stain to me.
21 Apr 2024 07:51
- jmagda
- Topic Author
Baking soda trick is a great idea. Tried it. No bubbles, so I guess it is oil. From where, I have no clue.
- Schu
Replied by Schu on topic Foam under the seat that protects battery top
My guess is the breather strip that runs across the top of the battery is made up of components or chemicals that are not compatible with the foam material. I’ve seen that happen with other materials in my past. You could maybe test it by putting layer of cellophane or Saran Wrap over the battery and pinch it in place when you close the seat. Leave it for a duration long enough to see if it stops the effect.
CT1B, CT1C, JT1, JT2, DT360A, GT80B, DT100B, DT125B,
DT175B, DT175C, DT250B, DT400B, Z50, SCR950
The following user(s) Liked this Post: jmagda, Snglsmkr, Ht1kid
21 Apr 2024 09:55
