Welcome, Guest
13 Jul 2018
I have re-enabled Tapatalk and will try to keep it functional assuming they keep the plug in updated. You can get the mobile app at: www.tapatalk.com/tapatalk_mobile
  • Page:
  • 1
TOPIC: 75 mx400b monoshock adjustment
75 mx400b monoshock adjustment 12 Aug 2017 02:04 #1
  • teemercer1979
  • teemercer1979's Avatar Topic Author
  • Newbie
  • Newbie
Looking to adjust the suspension on the bike. Notice when I sit on bike it sits kinda low. Where do I start at
75 mx400b monoshock adjustment 12 Aug 2017 10:08 #2
  • Enduronut
  • Enduronut's Avatar
  • Founder Moderator
  • Founder Moderator
I don't have any personal experience in adjusting that particular shock, but I think you might find all that information in our down loadable data base > > >
1. "Tech Library" . . . (find the link near top of this forum's home page)
2. click on "Service Manuals" . . . .
3. then look for a Manual called "Monocross Service Manual" . . .
4. adjustments are discussed in section 9 of that manual.
Control your thoughts . . . or your thoughts will control you!.
You can't accomplish . . . what you haven't dreamed!
Last Edit: by Enduronut.
75 mx400b monoshock adjustment 13 Aug 2017 04:31 #3
  • RT325
  • RT325's Avatar
  • Collector
  • Collector
www.yamaha-enduros.com/index.php/worksho...cument.viewdoc&id=33
I had the 250 model in "75 but same suspension & apart from changing the spring or packing the spring up tighter i don't think it's adjustable. When i sold mine the next year the guy had the shock modified for more travel which sat it higher so must have shortened a spacer internally or left it out totally. Number 31[make that 28] in the pic in the link looks like a spacer. In the numbers down the side they call it a stopper. One other thing which probably isn't relevant but on XT550 models the Swing/arm would spread in the loop up to the shock if you went motocrossing them & had hard landings where they would bottom out. Would be noticeable if that was the case.
edit--not sure what pic i was looking at but first shock parts pic on the link it looks like No28 as the spacer.
Last Edit: by RT325.
  • Page:
  • 1
Moderators: DEETDevinDmanEnduronutMakotosunVinnieyamadminJames Hart
Powered by Kunena Forum
