1972 DT2 MX CARB JETTING
  • JIMMYT70
  • JIMMYT70's Avatar Topic Author
1972 DT2 MX CARB JETTING was created by JIMMYT70
Can someone tell me the stock main jet size and stock pilot jet size on a 1972 dt2mx Thanks
26 Feb 2017 09:57 #1
Replied by MarkT on topic 1972 DT2 MX CARB JETTING
I didn't see jetting info in the Yamaha DT2 MX manuals in the Tech Library. Might just be me? :Ugh
For the DT2MX Clymer manual says:
Main 250
Needle jet P-5
Needle 6F5 (clip in groove 4 from the top)
Cutaway 2.5
Pilot 60
Air screw 1.0 turns open
Float level 25.5 mm
26 Feb 2017 11:05 #2
  • JIMMYT70
Replied by JIMMYT70 on topic 1972 DT2 MX CARB JETTING
Mark Thank you I never seen a bike so hard to get info on.
26 Feb 2017 14:54 #3
Replied by Swoop56 on topic 1972 DT2 MX CARB JETTING
Checked with Yamaha Service data sheet and Float level there differs from what Mark has quoted you . My information lists it as 20.7 mm + or - 1.0 mm .
That possibly could be two differing methods of measuring .
It's a significant difference , but when setting I'm sure it'll be obvious which particular value should be used .
27 Feb 2017 18:47 #4
  • JIMMYT70
27 Feb 2017 18:51 #5
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic 1972 DT2 MX CARB JETTING
Here's the info from the Yamaha bible we had at work back in the day. I can try & scan it better as just took multiple pics [easy way]. Had a DT2MX brand new--i'll find a pic. Float level is top of the next pic after the main carb setings .
28 Feb 2017 00:42 #6
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
more.
28 Feb 2017 00:46 #7
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
more.
28 Feb 2017 00:51 #8
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
cover.
28 Feb 2017 00:54 #9
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Few pics. Can't find mine but first one is brother inlaw on his RT2MX & other two are brother on his DT2MX.
28 Feb 2017 01:40 #10
