MX100 IGNITION
- Sneezles61
Replied by Sneezles61 on topic MX100 IGNITION
Yes, a lobe on the crankshaft..
I often wonder about the coil AND condenser... I'm not sure how to look up that info as to what could or could not work.. Perhaps that bit of info from the engineers didn't make it out to any manuals back then..
Sneezles61
Sneezles61
06 Jan 2022 03:38
#11
Replied by MarkT on topic MX100 IGNITION
DEET can rebuild your stator.
06 Jan 2022 07:15
#12
- Schu
Replied by Schu on topic MX100 IGNITION
The 360 and 400 that I converted to points ignition both had cams on the internal hub of the flywheel. So you had to swap the flywheel as part of the changeover.
CT1B, CT1C, JT1, JT2, DT360A, GT80B, DT100B, DT125B,
DT175B, DT175C, DT250B, DT400B, Z50, SCR950
06 Jan 2022 09:30
#13
I looked at your pic again and not sure why you'd need a new source coil... could be damaged from using the incorrect puller though?
Anyway, several on ebay. Here's one ebay link
Sneezles, used to relocate condensers all the time... several ways to do it. Midlife Motor posted his method here. yamaha-enduros.com/index.php/forums/74-7...er-relocation#106154
The following user(s) Liked this Post: Sneezles61, Mkdxxx
06 Jan 2022 09:46
#14
- Sneezles61
Thank you Mark.. I've always thought it shouldn't matter where.. just that it IS in the circuit..
And doing more looking about the coil to use ..or not.. The ignition source/stator coil along with the coil and the spark plug heat are in concert with each other.. Mated.. matched.. however you'd care to call it..
Sneezles61
Sneezles61
06 Jan 2022 10:39
#15
I've found the Yamaha points magneto on these bikes to be remarkably flexible in terms of ignition coil. It's an "Energy Transfer" type magneto which some have called a "mechanical CDI" as the principle is similar. Ignition coil is just an AC step-up transformer that converts the voltage pulse (hundreds) when the points open or the capacitor discharges into the high voltage pulse (tens of thousands) need to jump the spark gap and ignite the mixture. Biggest problem with ignition coils is some of the cheap junk sold out there.
Spark plug heat range has nothing to do with the "electrical" part of things... the center firing tip of the plug is exposed to the intense heat of combustion and needs to shed that heat. Tip has to stay hot enough to burn off deposits but not so hot that it burns up or turns into a glow plug. The heat management is done by increasing or decreasing the distance of the heat path by changing plug construction. www.autozone.com/znetrgs/repair_guide_co...0900c1528005c68d.gif
Best advice is to use OEM parts when you can...
06 Jan 2022 11:15
#16
- Sneezles61
I apologize for diverting the OP post..
Thank you again Mark... damn cold out up here, so reading into how things work..
I figured the long plugs were because of the aluminum head needed more mass... I'll stop my query's now..
Sneezles61
Sneezles61
The following user(s) Liked this Post: Mkdxxx
06 Jan 2022 12:01
#17
It's not the thread length in the head... it's the internal ceramic insulator length.
06 Jan 2022 12:15
#18
- Mkdxxx
Replied by Mkdxxx on topic MX100 IGNITION
What's a deet???
I don't know the history of this bike. I bought as is for very little money and owner said it had been sitting for a long time. Source coil is coming unwrapped. I have yet to test but it doesn't look chewed up. Flywheel was off when i bought it. Could be fine but I want to make sure the electrical system is solid. Points are very dirty...again sitting for long time. I toyed with the idea of switching it out to cdi but as you guys recommended thats not the best solution. From a parts perspective the points and condenser are still available to buy. That ebay link shows a mx80. Is that going to be the same thing? I expect so. gt80,mx80,dt100,mx100 etc. is there a difference between a coil used for points and a coil used for CDI? Thinner wire????
more questions...what's a stator in the context of this machine? Are all the ignition parts interchangeable in models...i tried getting parts for a 90 rt100 but no luck.
DEET is a "who".
I went by the part number and parts sometimes fit many models.
06 Jan 2022 20:40
#20
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
