piston/rings for DT250
23 Nov 2018 19:58
tvl
Newbie
Newbie
More
piston/rings for DT250 #1
Need a new piston and rings for the 75 DT250 438-11631-01-96/438-11610-00-00. So if anybody has any to sell let me know.
24 Nov 2018 10:50 27 Mar 2020 08:22 by Enduronut.
Enduronut
Founder Moderator
Founder Moderator
More
piston/rings for DT250 #2
There are plenty of std size pistons on eBay, but the standard size rings to match it are quite scarce, and VERY expensive when found.
So, this is what I'd suggest . . . .
Save your money and buy this TY250 set from the UK . . . which just so happens to be the exact same piston that your Enduro model used.
Sorry folks . . . . my link seems to have disappeared :huh:
Control your thoughts . . . or your thoughts will control you!.
You can't accomplish . . . what you haven't dreamed!
The following user(s) Liked this Post Rick C., Blackhat250, mdscott, Snglsmkr
24 Nov 2018 21:26
tvl
Newbie
Newbie
More
piston/rings for DT250 #3
Thanks for the that info EN . I will probably go that way.
03 Dec 2018 16:40
Delcowizzid
Sportsman
Sportsman
More
piston/rings for DT250 #4
I just bought one of 2 sets of standard rings listed on eBay from England just to get the bike running good enough to see if its worth spending more money .I'll be going oversize soon after
03 Dec 2018 22:33
RT325
Collector
Collector
More
piston/rings for DT250 #5
Wow that's a cheap piston kit. Will be aftermarket but what the hell. Looks great.
26 Mar 2020 12:28
Camp3
Site Supporter
Site Supporter
More
piston/rings for DT250 #6
This is a question from an inexperienced motor/piston guy. What is the feasibility of taking a 1st O/s ring set and measuring and filing it for the proper ring gap, taking pains to endure the ends are filed square etc and using them in place of the very scarce STD ring set for the DT250A,B,C. It seems as though it would be slightly out of round and not provide optimal sealing. I would like to get an older motor running with a "decent" piston and bore on the cheap, bore and hone later...I'd like to have 2 bikes (1974 DT2050A's) running this spring and my main project is stealing all the budget..
Thoughts?
1976 DT175C
1975 DT100B Kid Trainer
1974 DT250A In Process
1992 FJ1200
26 Mar 2020 13:42
Swoop56
Site Supporter
Site Supporter
More
piston/rings for DT250 #7
I don't believe that would work . Filing back the ring ends could be done ,
but that would need the ring peg recesses to be altered too , and I don't think
that would be manageable with just a file .
26 Mar 2020 19:02
mdscott
Site Supporter
Site Supporter
More
piston/rings for DT250 #8
Swoop56 wrote: I don't believe that would work . Filing back the ring ends could be done ,
I guess in desperate times it could be done, I have files rings to fit but it was for a 4 stroke engine, no locating pin.
Thanks Mark
Roseville, Ca.
'76 Bultaco 143 Frontera
'06 GL1800
'01 KDX200
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
26 Mar 2020 20:24
MarkT
Site Supporter
Site Supporter
More
piston/rings for DT250 #9
:whistle: :whistle: :whistle:
I've done it... worked fine... Yamaha oversize is ~0.010" diameter larger x Pi = 0.031416"
Stock rings tend to have a gap on the large side and the bore is likely worn slightly so you're probably talking about removing a max of about 0.014" from each ring end... 0.028" total.
That's equivalent to taking off the thickness of 3 to 4 sheets of paper from each ring end... not much at all. The Yamaha rings had a pretty big notch for the pin so I didn't touch that... there was still more than enough clearance.
Not saying it's the best thing to do but this was many years ago (before the Internet) and I had found a new piston but the only rings available were one size bigger. The machinist at the shop said it would be fine... he had a cool "piston ring file"... had a wheel with a hand crank... that he let me use and he helped me fit the rings to the new bore... didn't take much at all.
The following user(s) Liked this Post Swoop56, darinm
27 Mar 2020 04:23
Camp3
Site Supporter
Site Supporter
More
piston/rings for DT250 #10
Thanks all for responding. I think I will get the rings, measure, and file as best I can. The bore is in need of some attention so I think it may be ok to try this. If nothing else I will have learned more about these small engines.
Interesting method of using a dremel...maybe this will work, I have all the pieces..
www.homemadetools.net/homemade-piston-ring-gap-filer
1976 DT175C
1992 FJ1200
