68 DT1 shift shaft
  • tvrc18
  • tvrc18's Avatar Topic Author
68 DT1 shift shaft was created by tvrc18
Need a shift shaft that has splines on each end like the early DT1's. Mine is bent and the one Speed and Sport sent me does not have the splines on both sides.
16 Sep 2021 17:17 #1
Replied by Swoop56 on topic 68 DT1 shift shaft
The shift shaft you have received from S & S is the superceded part , fitted to DT2 & 3 .
The part you want , still turns up on Ebay occasionally   214-18125-00  .
The part you received will work , but if you want it in original condition Ebay is your friend .
Well , until you find out what they sell for .  LOL
The following user(s) Liked this Post: MarkT, Jack
16 Sep 2021 19:37 #2
  • tvrc18
Replied by tvrc18 on topic 68 DT1 shift shaft
Does it just sit flush with the outside of the seal on the right side then?
16 Sep 2021 19:41 #3
Replied by RT325 on topic 68 DT1 shift shaft
Can you make an alloy plug to block it off. Think DT2's have a small hump there so possibly 'that' DT2 shaft in a "68 will sit out in the seal ok--i hope.
Don't bin your old one as could be straightened easy enough especially if the splines are serviceable.
Last edit: 16 Sep 2021 20:57 by RT325.
16 Sep 2021 20:55 #4
I believe the plain  end probably sits flush or even slightly proud of the right side seal .
16 Sep 2021 23:15 #5
Replied by 1971DT250 on topic 68 DT1 shift shaft
This is a '71 RT1B-360 that was "restored" by someone else. He used a shaft for the '72-'73' DT/RT. It works.
The longer '68-'71 shaft is harder to find. Used ones usually have damaged/worn splines on the end for the shift lever..
Last edit: 17 Sep 2021 04:34 by 1971DT250.
17 Sep 2021 04:30 #6
  • tvrc18
The shaft with splines on both ends sure makes it much easier to adjust the shift mechanism because you can put the shifter on the clutch side and watch things as you shift, with the shifter on the other side sure is hard with the engine in the frame to shift and see what is happening. I just want it to look correct also with the rubber plug on the right side covering the shaft.
The following user(s) Liked this Post: 1971DT250, RT325
17 Sep 2021 04:38 #7
Haha, good point that Tvrc18.
17 Sep 2021 05:10 #8
