TY80, GT80,DT80 clutch adjust question.
- PDXtyist
- Content Contributor
TY80, GT80,DT80 clutch adjust question. was created by PDXtyist
I could sure use a hand in setting my TY80A’s clutch.
Symptoms are: rather hard to operate despite new cables. And, the clutch seems to engage at once. Not at all a gradual release into gear. It lunges at once about half way letting the hand lever out.
The manual is hard to figure out. So any help would be appreciated.
Thanks.
Thanks.
26 May 2018 09:45
- 1971DT250
Replied by 1971DT250 on topic TY80, GT80,DT80 clutch adjust question.
Sounds like the basket is "combed". This happens with hard riding where the tabs on the clutch friction plates wear grooves in the basket fingers.
Have you had the clutch apart?
The following user(s) Liked this Post: PDXtyist
26 May 2018 11:55
- PDXtyist
Replied by PDXtyist on topic TY80, GT80,DT80 clutch adjust question.
Thanks 1971....
I haven’t yet looked at clutch. So that I can learn from this, is the combing causing the stiffest or the sudden release or all of the above?
And, I’ve seen where de-burr with a file remedies this too?? Or new plates?
Thanks.
Thanks.
26 May 2018 13:02
- 1971DT250
Yes the combing will cause the tabs on the friction plates to hang up instead of moving smoothly. I have filed the burrs on clutch baskets before.
26 May 2018 15:19
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
