Rex's TY Electronic Ignition Kits
- Rexs Speedshop
- Supporting Moderator
Rex's TY Electronic Ignition Kits was created by Rexs Speedshop
We now have electronic ignition kit for TY175 and TY250 twin shock models. Kits for mono shock bikes will come once we've had a chance to do some work on timing curves - the engines have very different needs to the Twin Shock models!
All of our TY kits feature our "Dual Power" stator, this quite simply delivers significantly more power than any other electronic ignition for the TY.
Clubman kits have a single timing curve, one developed on real bikes and tested under real Trials conditions.
Pro kits have a second timing curve selectable on a handle bar switch. This is used for hill climbing. Im not going to tell you how much it improves the engine's power, you'll see for yourselves and hear from people who have it.
We have TY175 kits (RMK-1 Clubman or TY175 Pro) and TY250 Twin Shock (RMK-3 Clubman or RMK-3 Pro)
www.rexs-speedshop.com/epages/es143131.s...Electronics/TY_Parts
If you are in the UK, have a good running mono and are prepared to loan the bike, we will supply a kit free of charge.
Electronic Ignition Design & Manufacture*12 Volt Conversions*Electrical Parts*Generator Rewinds & Overhaul
24 Feb 2018 10:36
- Makotosun
- Administrator
Replied by Makotosun on topic Rex's TY Electronic Ignition Kits
Hi Marcus - have got the DT 250/360/400 setups available again yet?
24 Feb 2018 10:47
- Rexs Speedshop
Replied by Rexs Speedshop on topic Rex's TY Electronic Ignition Kits
Part of the message is hidden for the guests. Please log in or register to see it.
Very soon!
These kits have been under a massive re-design. I've done A LOT of work since the very first ones and now these are much improved.
The new kits are bolt on and go - no timing to adjust. That's just one of the new features.
We will offer a standard range of kits for various models (250/36/400cc models) with standard electronic and "Dual Power" ignition for competition use and bolt on power for road bikes. Both options can run ignition only or with a 12 volt lighting set.
There will be ready to go kits and for those who want more we can custom build a kit to their requirements (this will be at the kit price plus the additional parts/work). There will be different timing curves and eventually digital ones. We are getting VERY good results working with riders and getting a timing curve right for each engine.
I'm doing the DT250MX now then I'm looking for bikes!
Just be aware that specs are likely to change on kits shown but not in stock as we are still working on final versions.
Retail ready kits included the RMK-1, RMK-2, RMK-3 & RMK-4, these are as described and in stock.
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
