New 1976 TY175 Project
Replied by MarkT on topic New 1976 TY175 Project
- SlowPoke
Replied by SlowPoke on topic New 1976 TY175 Project
2014 Yamaha Bolt
2009 Yamaha XT250
1977 Yamaha DT250
Hammond Organ
Fender Bass
- SlowPoke
I picked up my piston but I need a bit of advice on the process of gapping the rings and installing them. Could someone explain the best process for this?
2014 Yamaha Bolt
2009 Yamaha XT250
1977 Yamaha DT250
Hammond Organ
Fender Bass
- Wheel mad
Replied by Wheel mad on topic New 1976 TY175 Project
Some have a mark on the ring to indicate up. Now the fun part, I usually hold the piston in hand but you may want to hold it in something... gently.
I put one end of the ring against the pin in the ring groove then using one thumb to open the ring up use other thumb to work the ring around and down over the head of piston. Move that ring to bottom groove and start again. Hope that helps
- SlowPoke
2014 Yamaha Bolt
2009 Yamaha XT250
1977 Yamaha DT250
Hammond Organ
Fender Bass
- Rexs Speedshop
- Supporting Moderator
Replied by Rexs Speedshop on topic New 1976 TY175 Project
www.rexs-speedshop.com/epages/es143131.s...Electronics/TY_Parts
SlowPoke wrote: I was curious what the gap tolerances should be.
If you can't find the TY specs and someone else doesn't have them, I would be very comfortable using the DT175 ring end gap specs.
- SlowPoke
2014 Yamaha Bolt
2009 Yamaha XT250
1977 Yamaha DT250
Hammond Organ
Fender Bass
- SlowPoke
Rexs Speedshop wrote: You just need a shiny new ignition now :-) :-) :-)
.......and, of course, you are right. So perfectly right.
2014 Yamaha Bolt
2009 Yamaha XT250
1977 Yamaha DT250
Hammond Organ
Fender Bass
- PDXtyist
- Content Contributor
Replied by PDXtyist on topic New 1976 TY175 Project
What mods do you recommend on the TY175C?
