Welcome, Guest
TOPIC: Bultaco 143 Frontera 360
Bultaco 143 Frontera 360 04 Jan 2019 18:13 #111
  • Site Contributor
  • Site Contributor
yamahahaha wrote: Sure would like to hear that Bul run !!!!!!!
A lot of us would! :Throttle
Bultaco 143 Frontera 360 04 Jan 2019 23:41 #112
  • mdscott
  • mdscott's Avatar Topic Author
  • Site Contributor
  • Site Contributor
Bike broke me, cant afford gas now.
The following user(s) Liked this Post: Hammer, Wheel mad
Thanks Mark
Roseville, Ca.
'76 Bultaco 143 Frontera
07 DL650
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Bultaco 143 Frontera 360 05 Jan 2019 09:22 #113
  • mdscott
  • Site Contributor
  • Site Contributor
I found out some good news, when cylinder was off to bore I noticed the number 136 stamped. 136 is a Pursang 360 MK8 74-76, the Frontera is nice low end torque, Pursang is more top end HP, I didn’t want to lose bottom end torque . Apparently they use the same cylinder, the only difference is the Pursang has a high compression twin plug head, and different designed expansion chamber. I have the oem pipe and the Frontera head. So this was good news.
Thanks Mark
Roseville, Ca.
07 DL650
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Bultaco 143 Frontera 360 05 Jan 2019 12:26 #114
  • yamahahaha
  • yamahahaha's Avatar
  • Site Contributor
  • Site Contributor
Yes that was one of the things I liked that Bultaco did. When you bought a cylinder you knew what bike it was for or from
Bultaco 143 Frontera 360 11 Jan 2019 22:59 #115
  • mdscott
  • Site Contributor
  • Site Contributor
Well I started the bike up and running, few laps around the block filling neighborhood with smoke doing a mosquito abatement. I though I was going to foul a plug, glad I put in a hot plug. I'll post some videos running. Need to do something about the brakes, real bad. New shoes and lubed where needed. Bultaco FB guys gave me some ideas, including levers with more leverage, one guy likes clutch lever off a KX250 1986-2007 . Also the carb needs a stronger spring, parked revving engine high sometimes it doesn't return to idle, didn't happen when riding bike.
Otherwise runs great, all gears, all metal clutch ok.
The following user(s) Liked this Post: Hammer, darinm
Thanks Mark
Roseville, Ca.
07 DL650
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Bultaco 143 Frontera 360 12 Jan 2019 04:41 #116
  • yamahahaha
  • Site Contributor
  • Site Contributor
Come on Mark get that video on here. Even if it's just an idling video. I miss hearing the wop wop sound of the old Buls. Don't get me wrong I like the brapp sound of the Japanese bikes also
Last Edit: by yamahahaha.
Bultaco 143 Frontera 360 12 Jan 2019 10:44 #117
  • mdscott
  • Site Contributor
  • Site Contributor
yamahahaha wrote: Come on Mark get that video on here. Even if it's just an idling video. I miss hearing the wop wop sound of the old Buls. Don't get me wrong I like the brapp sound of the Japanese bikes also
ok, I had to cut short the video , nieghbor was loading her kid in the car. :S
Thanks Mark
Roseville, Ca.
07 DL650
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Bultaco 143 Frontera 360 13 Jan 2019 14:39 #118
  • mdscott
  • Site Contributor
  • Site Contributor
Here she is running.
The following user(s) Liked this Post: 2fishkev, JGersh, KennyV
Thanks Mark
Roseville, Ca.
07 DL650
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Bultaco 143 Frontera 360 13 Jan 2019 14:57 #119
  • yamahahaha
  • Site Contributor
  • Site Contributor
Sweet :OnFire
Bultaco 143 Frontera 360 13 Jan 2019 21:28 #120
  • mdscott
  • Site Contributor
  • Site Contributor
mdscott wrote: Well I started the bike up and running, few laps around the block filling neighborhood with smoke doing a mosquito abatement. I though I was going to foul a plug, glad I put in a hot plug. I'll post some videos running. Need to do something about the brakes, real bad. New shoes and lubed where needed. Bultaco FB guys gave me some ideas, including levers with more leverage, one guy likes clutch lever off a KX250 1986-2007 . Also the carb needs a stronger spring, parked revving engine high sometimes it doesn't return to idle, didn't happen when riding bike.
Got the brakes working much better, put I a longer stiffer carb slide spring, polished the slide, so all good so far.
Thanks Mark
Roseville, Ca.
07 DL650
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
Last Edit: by mdscott.
Moderators: DEETDevinDmanEnduronutMakotosunVinnieyamadminJames HartMarkT
