Picture Attachment problem (09 Jul 2022)
Due to the extraordinary growth of the membership and resources, we are once again bumping up against hosting limits. I am working on a fix. In the meantime, the forum should function, but you won’t be able to attach images. Working as fast s we can to fix. Thanks for your patience. - Makotosun
Yamaha clamp on mirror sizes question.
  • msavitt
  • msavitt's Avatar
Replied by msavitt on topic Yamaha clamp on mirror sizes question.
I think you can determine with your particulars and my zip code of 92679 here  www.usps.com/international/preparing-int...tional-shipments.htm   send me shipping and I will be glad to pack it up and send it to you for $0 in honor of HRH
on another topic - any idea where I can get a used air box cover for my R5?  I am using a Uni filter, thinking perhaps I don't use a cover at all if doing so doesn't throw off the intake dynamics.  what you think?
23 Sep 2022 10:16 #11
  • Gr8uncleal
  • Gr8uncleal's Avatar Topic Author
Replied by Gr8uncleal on topic Yamaha clamp on mirror sizes question.
OK.
What is approximate weight, including packing?
Regarding the R5 airbox lid, I would say that you definitely need it.
The original style was replaced during the R5 production run and the RD250/350, 1973 to 1975, used the same part. Keep an eye out on fleabay.com for one in the US - they come up on a regular basis, but prices fluctuate wildly, depending on whether or not a seller knows what some folks are prepared to pay for them! Also keep an eye on job lots, as one might turn up in one of those.
23 Sep 2022 10:50 #12
  • msavitt
  • msavitt's Avatar
1lb and 14”x5”x3” should work
its free and quite clean post evaporust but the silvering got dissolved by the evaporust!
23 Sep 2022 21:09 #13
  • msavitt
  • msavitt's Avatar
No small Allen screw
held in place with Shorter perpendicular bolt that gets drawn up by nut after inserting thru u clamp
let me know if you still want.  Glad to send and part of this as I decided to go with aftermarket mirrors held by 360 degree split clamps cause I grew up in Chicago and need to always watch my back!
24 Sep 2022 10:25 #14
  • Gr8uncleal
Thanks Martin, but are you sure that there's no small headless screw? It's not obvious at first glance - photos of mine attached, but after my allen key snapped off inside it and I failed in my attempt to drill it out!
25 Sep 2022 01:38 #15
  • msavitt
  • msavitt's Avatar
No set screw
it scrunches up like in last pic.
the nut and bolt wasn’t part of this, a brain fart
the mirror shaft measures 10mm / 0.383” so perhaps you can use the small shaft and associated bits to mount your?
25 Sep 2022 07:56 #16
Replied by MarkT on topic Yamaha clamp on mirror sizes question.
Gr8uncleal, that set screw is drilled off center...  almost certainly is was added by a "backyard engineer"?
25 Sep 2022 08:04 #17
  • Gr8uncleal
Thanks both.
Yes, could be a diy job. However, probably not a genuine Yamaha mirror, so could be a cheap repro.
Would the threaded part be threaded at both ends, like an exhaust stud? I'm trying to suss out how it might be removed. I have a couple of nos mirrors in this style, but without the threaded length, so they must be removable.
25 Sep 2022 08:36 #18
