Picture Attachment problem (09 Jul 2022)
Due to the extraordinary growth of the membership and resources, we are once again bumping up against hosting limits. I am working on a fix. In the meantime, the forum should function, but you won’t be able to attach images. Working as fast s we can to fix. Thanks for your patience. - Makotosun
2K gloss clear in small rattle can?
  • AirborneSilva
  • Platinum Member
  • Platinum Member
2K gloss clear in small rattle can? was created by AirborneSilva
Not sure if this belongs here or not...  I need to paint a replacement oil tank as my original leaks like an old Harley and want to clear it with 2K gloss but can't find any cans smaller than the 11 oz. cans, does smaller one even exist?  I don't want to waste probably more then 3/4 of a can if I can help it.  Thanks!
1972 DT2 250
26 Jul 2022 16:58 #1
Replied by Mark350 on topic 2K gloss clear in small rattle can?
Don't know about smaller spray cans of the 2K, but if you don't use all 11 ounces if you refrigerate the remainder. It will last about 6-7 weeks with no ill effects.
26 Jul 2022 18:03 #2
Replied by Ht1kid on topic 2K gloss clear in small rattle can?
Spraymax 2k makes a 7 oz clear for headlights same product that’s what I buy for small jobs. Paint store confirmed it’s the same
The following user(s) Liked this Post: MarkT, AirborneSilva
26 Jul 2022 20:26 #3
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic 2K gloss clear in small rattle can?
Thanks guys, both good tips!
1972 DT2 250
27 Jul 2022 02:09 #4
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Next question, for my DT2 that has two stripes on the tank I've bought the decals to put on so do I spray the clear over the decals and if so do I sand the tank before putting on the decals then clear?
1972 DT2 250
27 Jul 2022 02:44 #5
Replied by Gr8uncleal on topic 2K gloss clear in small rattle can?
Hello Tony.
Originally the decals wouldn't have been clear coated over. However, a lot of restorers clear coat over them, presumably to stop them starting to peel off at the corners, which the originals eventually did.
The following user(s) Liked this Post: LETSJET
27 Jul 2022 04:01 #6
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks Alan, I'll have to give it some thought about how I want to do it.
1972 DT2 250
27 Jul 2022 07:30 #7
Replied by Pedalcrazy on topic 2K gloss clear in small rattle can?
Unless you bought NOS old original Yamaha decals then you'll need to clear over them. All the repro decals I've bought specify in the directions that they must be clear coated. Probably a different material that won't hold up to Sun and weather. I've never gone against the manufacturers instructions.
1968 DT1 (Project)
27 Jul 2022 18:11 #8
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thanks, I did get repro from feebay.  Will I need to scuff the paint before clear?  I obviously will have to wait until base coat is dry before I can put the decal on so I'm thinking I need to scuff...
1972 DT2 250
28 Jul 2022 02:36 #9
