Picture Attachment problem (09 Jul 2022)
Due to the extraordinary growth of the membership and resources, we are once again bumping up against hosting limits. I am working on a fix. In the meantime, the forum should function, but you won’t be able to attach images. Working as fast s we can to fix. Thanks for your patience. - Makotosun
Yellow wire with black stripe - purpose and application
  • Gr8uncleal
  • Gr8uncleal's Avatar Topic Author
I'm trying to id a Yamaha left switchgear with YHA206 stamped on the underside.
The wires for the lights on/off and high/low have been chopped short. If I can find out what it was originally fitted to, then I can restore it.
One of the wires is coloured yellow with a black stripe and appears associated with the lights "off" function. This is not a wire colour that I'm familiar with, so I was wondering if anyone here could enlighten me.
I am in the UK. If the switchgear was originally fitted to a UK bike then, given the differences in UK/US lights set up, maybe the yellow/black wire wasn't fitted to US models. Anyway, no harm in asking and, with members worldwide, someone might know!
Many thanks.
Last edit: 13 Jan 2022 10:02 by Gr8uncleal.
13 Jan 2022 10:00 #1
Is the attached diagram any help?  It's for a Yamaha TY250. It shows a yel/bk wire in the light circuit.  Often specific  wire colors have the same use on different models.
The following user(s) Liked this Post: MarkT, Gr8uncleal, Ht1kid, Tinkicker
13 Jan 2022 15:40 #2
  • Gr8uncleal
Thanks very much. Yes, it is a great starting point.
Are you able to let me know which year and market (eg US, UK, Euro, Oceania) the diagram is for? Also, I can't quite read the name of the item that the yellow/black wire goes to (number 7).
I shall continue to research later on today, so I might find answers then.
Thanks again.
14 Jan 2022 00:37 #3
Tell me if i'm wrong, but i think its related to a resistor--'not a regulator'--but a resistor to soak up power equal to the headlight wattage when in the park position--if you call it park. Riding with tail light & park light on during daylight but not the headlight. We had that setup on V50 scooters by memory. I've got an old one here somewhere with a broken mount off a DT250 mono from about "78 i think it was.
14 Jan 2022 01:06 #4
  • Gr8uncleal
Thanks Morley and I can see the logic in that.
14 Jan 2022 01:58 #5
Yes, I agree.  It looks like resistor is used when key is in a position for marker lights to be on but headlight is off?
14 Jan 2022 06:08 #6
That's not an arrangement I've seen on US bikes...  not to say it doesn't exist on some model.
Closest thing I've seen is on the US RT180 where Yamaha used a regulator and a resistor because the only light was the low oil warning...  no battery either.
14 Jan 2022 06:16 #7
Gr8uncleal, here is a screenshot of the diagram I found.  Hope it answers your question.
Last edit: 14 Jan 2022 17:44 by Hardworker.
14 Jan 2022 17:41 #8
  • Gr8uncleal
Yes it does, thank you, and it also shows the website at the top, which might have more useful parts reference material.
14 Jan 2022 23:57 #9
