Compression
Replied by Gr8uncleal on topic Compression
davidscott95 wrote: Hello all. I am new here. could not figure out how to post a new question!!! so I am posting here.
I just got a 1976 (i think) IT400. does not run. no spark. my first assumption is the kill switch. it is really rusty. the bike was sitting outside and has a lot of rust on it, so my next step will be looking at the magneto. But I also want to ask about compression? what range is acceptable? and on this bike, it has a auto decompression box on the front of the cylinder? how does that work? and how do i check compression with that thing in it? Also, the head has TWO spark plug holes! I seem to recall back in the day, we had the second one used as a decompressor. so why would they have one on this if it has the automatic one?
I am sure I will have lots of questions as I get into this bike and tear it down. will probably rebuild the entire bike. so hope to get help from you experts out there!
thanks.
I've attached a link below to the IT section. To start a new thread, press "New Topic" on the left.
yamaha-enduros.com/index.php/forums/all-about-the-it-models
Replied by RT325 on topic Compression
If the decomp isn't working but is shut & sealing pretty good then you should have compression you could just about stand on for a second or two. But so long as you can feel a reasonable bump then it should run. if the decomp is leaking then it should still run as it's designed to start with it open & just bleeds off some off the compression from a hole above the exhaust port. With the rusty kill switch the problem probably isn't in there as just shorts out to stop so chances are it won't short out--so in other words it shouldn't stop it running. Can simply unplug it to eliminate anything going on there. Be nice if you can get it running before dismantling it. I had an IT400 motor the same in a DT250 frame years ago. Was a fun bike. Just be careful with no kill switch if something goes wrong like the throttle sticking. Be sure throttle is operating & shutting right down before trying to start it. I'm forgetting it doesn't spark. CDI spark never looks very strong.
- davidscott95
Replied by davidscott95 on topic Compression
- Blukas
Replied by Blukas on topic Compression
