Shift shaft tweaked - straighten or replace?
  • Gem80DT175
  • Gem80DT175's Avatar Topic Author
Was in the final stages of putting the top end back on of my first restore - 78 DT175 - and was cleaning up dirt/oil residue when I noticed the shift shaft is tweaked!  Is this likely the cause of the oil leakage?  Should I try to straighten it and put a new seal in?  Or a new shaft and seal, which would mean breaking down the engine I just put back together?  Wish I saw this soon! ugh.  Thanks for your input!!
25 May 2022 17:10 #1
Replied by 1971DT250 on topic Shift shaft tweaked - straighten or replace?
Very risky to try to straighten it while it's still in the engine. Might crack the case.
25 May 2022 18:10 #2
It looks like the seal is shot, there's a big old gap on the top. I might go ahead and try to replace the seal, if it's shifts okay, and just ride on.
25 May 2022 18:17 #3
I guess ya going to have to straighten it to get it out eventualy oneday. I think [hope] you'd be ok with a good fitting strong steel tube over it right up to the case with seal removed and give it some heave ho. Looks like it bent down without breaking the case & case looks stronger going upwards--i hope!!.
25 May 2022 19:20 #4
Replied by Sneezles61 on topic Shift shaft tweaked - straighten or replace?
My DT 250a has one of those! The bent shaft also reamed an oblong shape into the casing… mine is still in a box.. waiting until I have the time to pay attention to it..
Sneezles61
26 May 2022 05:25 #5
You only need to remove clutch cover to change shaft..
Challenge is getting bent one out without damaging case.  Several ways to do it...  all the ways I've done it require cutting/grinding shaft off and patience.
The following user(s) Liked this Post: Swoop56, HouseofEnduro, Ht1kid, Pete-RT1
26 May 2022 08:28 #6
Replied by Pete-RT1 on topic Shift shaft tweaked - straighten or replace?
It's not one I'd risk trying to straighten in situ, the risk of cracking the case is high and the ease of replacing the shaft with another makes that the best option in my opinion.
As Mark says, it can be replaced by removing the clutch cover.
Cut it off close to the left and case and ease it out, replacement in and off you go.
Yamaha RT-1
Yamaha CT1-B
Yamaha CT3
26 May 2022 09:57 #7
If it's bent inside the seal recess you may be able to cut off on clutch side and pull out from shifter side.
Or cut off on shifter side and use die grinder carefully on stub in recess until pulls out easily from clutch side
26 May 2022 10:55 #8
Replied by Vintage465 on topic Shift shaft tweaked - straighten or replace?
I'd make my descision based on the availability of a replacement shaft.  I think if you couldn't get a replacement, I'd split the cases and repair it.  I say split the cases cause I don't think you'd be able to pull it thu the cases from the clutch side with it being bent. I do believe with the cases would split even with it bent cause you get a little "play" as the cases come apart.  Even if I could replace it I'd still likely split the cases to get the bent one out and straighten it out to have for a spare.
11 Jun 2022 12:51 #9
I shouldn't say this, but it bent down without breaking the case, & case looks stronger going upwards--so--i'll leave it there!!
11 Jun 2022 15:17 #10
