1981 Yamaha DT175
15 Sep 2020 13:09
Smartlu57
Newbie
Newbie
More
1981 Yamaha DT175 #1
Hello,
I am looking for a little help or guidance. I'm working on rebuilding and restoring my childhood DT175. I recently just finished getting the motor running after replacing crank bearings and new pistons and rings. It started after 2 kicks so all good there. The issue I have is that it seems to have a messed up shift pattern, however I never took the actual gears in the transmission apart so I wondering what I have done wrong here when I reinstalled the transmission.
Thank you everyone in advance and glad to see so many people keeping these old bikes running!
15 Sep 2020 17:09
MarkT
Site Supporter
Site Supporter
More
1981 Yamaha DT175 #2
Welcome!
Nice story.
Need specific details on exactly what the problem is. I can't imagine how you could have messed up the shift pattern.
16 Sep 2020 19:22
Smartlu57
Newbie
Newbie
More
1981 Yamaha DT175 #3
I apologize I can’t be more specific but I think you answered my question. I installed the transmission exactly how it came out but the shift Forks came off when I split the case but I assume they only go in 1 way but could really be in any gear. So it’s very staring that I have a weird shift pattern where neutral is where 3rd usually is and it’s down 3 then back up to 4. I’m going to split the case again and try it again.
16 Sep 2020 20:05
MarkT
Site Supporter
Site Supporter
More
1981 Yamaha DT175 #4
That's a lot more specific than "weird shift pattern" :likey
Not sure I understand you completely though... it's a shift drum... completely linear. If you're in a gear and you move the lever down three and then back up one it's exactly the same as going down two from where you started. Impossible to be anything else. So that's probably not what you're saying.
Neutral is NOT a "gear"... it's just a "half shift" that puts the trans between gears... not handled internally.
Before splitting, check the alignment marks on the shift drum sector. It's in the manual. You can put the sector piece on with the pins 180 degrees out which could put neutral in the wrong place. Easy fix.
17 Sep 2020 08:52
Smartlu57
Newbie
Newbie
More
1981 Yamaha DT175 #5
Thanks Mark, I'll give that a try/look over before I get to deep.
I appreciate the help!
The following user(s) Liked this Post MarkT
