Anybody tried boyesen ports on the reed valve motor?
- turbodan
Anybody tried boyesen ports on the reed valve motor? was created by turbodan
I'm not looking for a screamer, just more power everywhere. The stock powerband is fine, there's just not enough of it.
- LongStride
Replied by LongStride on topic Anybody tried boyesen ports on the reed valve motor?
- turbodan
Replied by turbodan on topic Anybody tried boyesen ports on the reed valve motor?
- PMK
Replied by PMK on topic Anybody tried boyesen ports on the reed valve motor?
Not expecting any huge change, if that is needed it will be via modification to the cylinder head.
- RacerClam
Replied by RacerClam on topic Anybody tried boyesen ports on the reed valve motor?
Rich
- Delcowizzid
Replied by Delcowizzid on topic Anybody tried boyesen ports on the reed valve motor?
- turbodan
Regarding the original topic, these ports did not make a big difference with otherwise stock porting and a stock pipe. The transfer porting is so conservative that the stock intake is probably not a significant restriction. I would actually like to try going another way with a stock jug, using a piston without windows to close off the intake port sooner and boost crankcase compression. These boyesen ports are open to the intake at all times so there is no way to try my little experiment unless I epoxy the ports closed again.
With a good expansion chamber, suitable porting and a big carb, these ports would certainly be beneficial. The stock DT360 cylinder closes the crankcase from the intake port at BDC which diminishes the ability of the pipe to draw more mixture through during scavenging.
- shyted
Replied by shyted on topic Anybody tried boyesen ports on the reed valve motor?
They do have a tendency to run weak lowdown and rich up top. You would have to try them .
I think you would see better results just re cutting the reed block.
In other words, where its square at the top near the mount screws for the reeds, cut it back and make it into a half circle.
Knife edge it . Knife edge the other end where the end of the reeds rest, on the inside though.
Makes the bottom end smoother.
Then you have started something. Get the casting marks out the inlet tract, clean the transfers up, make sure the gaskets don't hang over the crank case or transfers. Match the piston ports up a little. You could put a flat slide Keihin on too.
Everything there , out with the carb, is free drivability not necessarily power but it is noticeable .
Regards Ted
- turbodan
shyted wrote: I read the KX 125 bit. I agree with Rich about Boysens but have no complaints about running them in my TDR 250.
Regards Ted
I installed the entire KX reed block. Replaced the stock unit completely, didn't bother trying to modify it. I've got some Boyesen reeds I was going to install but I remembered I had already modified this cylinder to fit the larger reed block.
The KX reed block is a six petal unit like the original but it benefits from 30 years of development. All I had to do was open up the cylinder a little bit as the KX reed block is slightly wider than the DT reed block.
I am running a 35mm Keihin PWK and an MX360 pipe as well. Its running pretty strong but I did just send the original cylinder and head off for professional help. The main transfer ports only have around 100 degrees of duration, I expect a significant improvement from proper porting.
Replied by RT325 on topic Anybody tried boyesen ports on the reed valve motor?
