Fork alternatives
- Jurhs
Fork alternatives was created by Jurhs
I have a 1995 Yamaha rt100 with bent forks. I ha met found any rt100 forks so are there any alternatives that will work?
18 Jan 2021 17:58
- 1971DT250
Replied by 1971DT250 on topic Fork alternatives
Contact these guys and see if they can make a set. I have some for the DT/RT, they are excellent quality.
franksforks.com/
franksforks.com/
19 Jan 2021 05:00
- Bigdog302
Replied by Bigdog302 on topic Fork alternatives
Dave
Jesus is Lord!
Dave
Jesus is Lord!
Replied by RT325 on topic Fork alternatives
Depending how bent. A. good engineer will be able to straighten them. I nearly always manage to do mine without pulling apart. Just support under the end of the lower slider & at the top of the tube & revolve it to find the high point & have 'that' directly under the press ram but using something semi soft at each point to avoid damage. Easy to say but takes time to get it right & easy to get it wrong. Always need to go 'past' the point of straight to de-stress it i find. Something like that.
19 Jan 2021 17:53
- Schu
Replied by Schu on topic Fork alternatives
If they aren't bent too bad you can try my method using a band clamp. It worked on my little JT forks.
yamaha-enduros.com/index.php/forums/mini...bent-forks-cheap-fix
CT175B, CT175C, JT1' JT2' DT360A, GT80B, DT100B, DT125B,
DT175B, DT175C, DT250B, DT400B, Z50, SCR950
19 Jan 2021 18:19
Or even try the reverse of Schu's good trick above & turn them exactly towards each other & lay the bike on its side then put a jack between the forks & jack them outwards until straight. On second thoughts maybe not. If i tried that the jack would fly out & hit me in the head knowing my luck lol.
20 Jan 2021 02:27
