1975 Yamaha DT125 Enduro 12 volt USA Version
  • Patroll330
  • Patroll330's Avatar Topic Author
Well no fire after getting the battery ,so started with the coil wire at the coil cut and got fresh wire for better contact still fire . Went down to the  Flywheel cover and took the cover off the points and over componets were covered with light rust so sprayed good penetrating oil in there.and gently cleaned in there some. I took pictures, the points have zero spring tention on my points. spring is proberly broken . And all all reliable help welcomed here . Thanks
09 Mar 2021 14:21 #1
