Welcome, Guest
  • Page:
  • 1
TOPIC: Dt 400 Wiring
Dt 400 Wiring 14 Mar 2019 12:38 #1
  • 78Dt400Kart
  • 78Dt400Kart's Avatar Topic Author
  • Newbie
  • Newbie
I'm putting a 78 DT 400 engine in to a go kart. I could use some help on the wiring. Does anyone have a basic wiring diagram. Obviously don't need turn signals or lights or anything like that, just need the thing to run. Also do I need any electrical components besides the cdi, harness, and the coil?
Last Edit: by 78Dt400Kart.
Dt 400 Wiring 14 Mar 2019 14:58 #2
  • 78Dt400Kart
  • Newbie
  • Newbie
Update I found this In the library but its for a 77. Is it the same for a 78?
This attachment is hidden for guests.
This message has an attachment file.
Dt 400 Wiring 16 Mar 2019 23:07 #3
  • 78Dt400Kart
  • Newbie
  • Newbie
My colors are different.
Dt 400 Wiring 17 Mar 2019 00:04 #4
  • Makotosun
  • Makotosun's Avatar
  • Site Administrator
  • Admin is in the House!
Are you sure of the year of your motor? Check the serial number to our vin tables.
The CDI box you have looks correct for the 77-78. Wiring should be the same for both.
Cdi Box, coil and the stock ignition should be most of what you need.
No Good Story ever started with a Salad . . .
Dt 400 Wiring 17 Mar 2019 07:42 #5
  • Site Contributor
  • Site Contributor
The white plug you have in your hand contains the neutral light wire (light blue), headlight circuit power (yellow), and battery charge to rectifier wire (green/white). None of those are required to make the engine run.
There is an individual black, brown, and white/red that go to the CDI box wires of the same color. (The Black also goes to chassis ground).
That leaves 3 wires on the CDI box... One black is not used.
The Orange goes to ignition coil. The Black/White is the kill button wire. If you ground the black/white it kills the spark.
I marked the wires on your picture.
The black wire with the X is the one not used.
S are the wires that go to stator (engine) The colors wire match 3 individual wires from stator.
C is wire to coil
K is wire to kill button. (grounding it kills engine)
The following user(s) Liked this Post: Wheel mad, Gr8uncleal, 78Dt400Kart
Last Edit: by MarkT.
Dt 400 Wiring 17 Mar 2019 07:46 #6
  • Site Contributor
  • Site Contributor
These are the wires out of stator you use for ignition system.
The following user(s) Liked this Post: Makotosun, Gr8uncleal, 78Dt400Kart
Dt 400 Wiring 20 Mar 2019 11:09 #7
  • 78Dt400Kart
  • Newbie
  • Newbie
Thanks A ton Mark! She is now running!
  • Page:
  • 1
Moderators: DEETDevinDmanEnduronutMakotosunVinnieyamadminJames Hart
