cleaning autolube pump
10 Sep 2019 00:12
liferbiker
Collector
Collector
More
cleaning autolube pump #1
Just got a 75dt125b saturday & PO has line off tank ?? how long, I'd feel better if I removed pump & cleaned it out. I was thinking of running diesel or a 50/50 oil fuel through it using wheel to get it through. Then straight oil same way & pump it dry. This sound ok?
10 Sep 2019 01:14
RT325
Collector
Collector
More
cleaning autolube pump #2
I'd guess if he had it capped off from the time he disconnected it then it should be ok to just hook up again & run to verify the pump is pumping & pull the cable at the pump for full stroke. I don't think a mix through it would do any harm--well it wouldn't but not sure its necessary. Mind you i've never had a pump give trouble back in the day, but now they're 40+ years older so the fun begins. Bleed it of course--just let it flow from the screw on the side.
10 Sep 2019 05:30
liferbiker
Collector
Collector
More
cleaning autolube pump #3
No, it wasn't capped is why I'd like to flush it out. Or, maybe clean tank, install fresh oil, bleed & pull pressure line off barrel until fresh oil pumped through. I also wanted to check for proper amounts of oil discharged but find no amounts givin in manual here. They list idle & full throttle stroke specs but nothing on amounts in cc's as I've seen in other specs.
10 Sep 2019 05:40
MarkT
Site Supporter
Site Supporter
More
cleaning autolube pump #4
Flow spec answered in your other post.
The following user(s) Liked this Post liferbiker
10 Sep 2019 06:54
Kayto
Mini Enduro
Mini Enduro
More
cleaning autolube pump #5
I'm not going to say that this is the absolutely best way to clean the pump, but when I cleaned the one for my '74 DT250, I removed it from the case, but did not disassemble it. I then immersed it in WD40 and turned the wheel on the pump. This circulated the fluid through it, and I could see that it was pumping out the outlet port. I finished it by immediately adding some 2-stroke oil into the pump and working it through, again by spinning the priming wheel. Having the pump off made it easer to check the end clearance for the stroke shaft also.
10 Sep 2019 08:53
Mauser
Open Class
Open Class
More
cleaning autolube pump #6
Kayto wrote: I'm not going to say that this is the absolutely best way to clean the pump, but when I cleaned the one for my '74 DT250, I removed it from the case, but did not disassemble it. I then immersed it in WD40 and turned the wheel on the pump. This circulated the fluid through it, and I could see that it was pumping out the outlet port. I finished it by immediately adding some 2-stroke oil into the pump and working it through, again by spinning the priming wheel. Having the pump off made it easer to check the end clearance for the stroke shaft also.
Good idea I have 1 to clean out for my friends DT175MX shortly.
RT2 ~ XR650R ~ DT175MX ~ ZX12R ~ XJR1300 ~ DT125LC ~ XR250R ~ XL125R ~ RD350LC ~ MT50 ~ GPZ1100
10 Sep 2019 08:56
liferbiker
Collector
Collector
More
cleaning autolube pump #7
This was my 1st thought (removing it) didn't think of wd40, that seems like a good fluid to use! thanks!
10 Sep 2019 13:47
Swoop56
Site Supporter
Site Supporter
More
cleaning autolube pump #8
Having been inside a couple of oil pumps ,
usually there are sludge deposits inside the main pump body .
I'm not sure you'd really clean those with just soaking .
They are pretty fiddly to work on . After I got frustrated with mine ,
I sent it off to DEET who successfully overhauled it , for a very
reasonable cost .
The following user(s) Liked this Post DEET, MarkT, swm, DVM
