RT1B Clutch
14 Jun 2019 05:27
Dave G
Novice
Novice
More
RT1B Clutch #1
I've got an RT1B 360 and need to replace the clutch plates
Any recommendations on where I might get these from? Or do any from other bikes fit?
Either UK or US
Cheers
14 Jun 2019 05:52
Mothersbaugh
Collector
Collector
More
RT1B Clutch #2
Clutch plates or friction plates? If friction plates, No. 6 here:
www.partzilla.com/catalog/yamaha/motorcycle/1971/rt1b/clutch
If clutch plates, someone into the RT's will answer you. Whole packs are probably still available, too, from somewhere, I'll bet, but you can also clean and prep your old clutch plates, I think I have heard people say here. Again someone into the RT's will come on.
The following user(s) Liked this Post Dave G, Oldbikenut
14 Jun 2019 20:41
Oldbikenut
Mini Enduro
Mini Enduro
More
RT1B Clutch #3
I just replaced my clutch with OEM friction plates all seems good.
14 Jun 2019 22:03 14 Jun 2019 22:07 by RT325.
RT325
Collector
Collector
More
RT1B Clutch #4
I've used all sorts of fibers but never sure what, just stuff i had under the bench. Some were full fiber which would be originals but have broken those or found them broken in motors i've pulled apart. But others i've used were alloy with bonded fiber & would be YZ or something much later DT or MX maybe.
Come to think--one of mine i did use new aftermarket full fiber plates i was given, can't think of the brand but one of the big name names--Barnett rings a bell but maybe not. Anyway--worked perfect.
