Premix question
04 Jun 2019 17:46
RT325
Collector
Collector
More
Premix question #11
Maybe it blew the right side seal out on startup after your ride. Unlikely though, but can't think of much else that would do it if it was ok on the first ride. Unless the oil separated out of the fuel but once again not likely. One random thought if the seal is still in place, has the crank nut unwound or come off so the oil could then get along the shaft, but once again, unlikely. If that'd happened you could feel end float in the crank from the mag side but then again--everything being as it should, the crank should be tight in the left bearing & bearing tight in the case so that theory is no gunna work.
07 Jun 2019 16:17 07 Jun 2019 16:21 by Jagarrett369.
Jagarrett369
Mini Enduro
Mini Enduro
More
Premix question #12
So maybe it’s a sitting for a while and me cranking the throttle 5 times before startup thing. I rode it for 10 miles today and it cleared right up... strange? Is this casterol 2 stroke variety the wrong thing? Do I need synthetic? Any answers and help is very much appreciated.
Attachment not found
also checked the plug and it is clean and non fouled. The transmission side is clean and looks and smelled like gear oil and not 2 stroke
07 Jun 2019 16:33
Midlife Motor
Sportsman
Sportsman
More
Premix question #13
Mothersbaugh wrote:
MarkT wrote: P.P.S. I type too slow. :haha
You type just fine. I just worked the button like the latest Jeopardy champion, who now, I see, has met his match and lost.
I'll take "Two Good Answers" for 100 Alex
08 Jun 2019 06:51 08 Jun 2019 06:52 by MarkT.
MarkT
Site Supporter
Site Supporter
More
Premix question #14
Not sure what "casterol" you are using... there are lots of oils and variations out there.
It doesn't really sound like you have a problem. Maybe it got "loaded up" a little and/or running a little rich.
Pictures are usually easy to attach here... click on the "attachments" button and then either browse to your photo files using the "add files" button or simply "drag and drop" the photos in to the designated area. Once a photo is added, you'll see an "insert" button to make it show up within the post or you can just leave it as an attachment.
08 Jun 2019 15:19
Jagarrett369
Mini Enduro
Mini Enduro
More
Premix question #15
Thanks again. Maybe I did just load it up.
The following user(s) Liked this Post MarkT
